Parts Wanted 2006 Looking for something in particular? Ask here.
Distributor needed!
Old Dec 22, 2005 | 10:55 PM
Kevin Knight's Avatar
Car: '82 & '84 Trans-Am
Engine: LG4 305 & L69 305 H.O.
Transmission: TH200C & 700 R4
Axle/Gears: 3:23 & 3:73 10 bolt
Distributor needed!
I'm looking for a distributor for a L(69) 305 H.O. Trans Am must be compatible with the E4ME carb, reasonable price would be appreciated. Thanks.
Old Dec 23, 2005 | 11:58 AM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
I've got the stock dizzy from my old 83 TA. It had a 4-barrel CC Quadrajet on a 305. Will that work for you? I'm pretty sure it will.
Old Dec 23, 2005 | 03:11 PM
Distributor.
Hi, If the CC means computer controlled it should be a E4ME set up, The 8th digit on your VIN should also be a "G", do you know if it is a H.O. 305? If the digit matches mine it should. It should not have a vacuum advance. Is it in working order? Thanks, Kevin.
Old Dec 23, 2005 | 07:45 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
I've got the factory disributor off of my '84 Z-28(L69). Make me an offer.
Old Dec 23, 2005 | 09:43 PM
Distributor.
Is 50.00 U.S. shipped fair? Assuming all the wiring leads are immaculate on it? Oh, and is your 8th digit a "G" on the VIN? By any chance do you accept Pay-pal? thanks dude, Kevin.
Old Dec 24, 2005 | 09:21 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
I'll have to take a look at the leads but it should be ok.I'll get back to you with the vin. And I don't have paypal-how about a money order?
Old Dec 24, 2005 | 03:21 PM
Distributor.
Yes, a money order will be fine, just e-mail me directly with your address, I assume the distributor was functional when last used? I need one I could just bolt in and work. If the 8th digit matches we have a deal. Thanks, Kev.
Old Dec 24, 2005 | 06:32 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
yes it worked before it was pulled. The 8th digit is a G. But its a L69(305H0) so its the same engine as the one in your sig, so I don't see why it wouldn't work. Email me at camaro@techemail.com if your still interested.
Old Dec 30, 2005 | 08:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
not all CCC ones(7 wire) were without the vacuum advance
i have seen many 7 wire CCC HEI with vacuum advance too
it is very random
you could run either one, it doesnt really matter, it all depends on if you want vacuum advance or totally computer controlled timing- rather than just the lack of mechanical advance that is found on the CCC HEI with vac advance
it is a common perception/assumption that all CCC HEI were without vac advance,
but it is not true
L69 and LG4 would be same unit other than possible different module number
good luck
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
tero
Aug 6, 2015 06:34 PM
