Power Door lock relay 89 firebird
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Power Door lock relay 88-92 firebird
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
is it the one inside the console ?
do you know part number on it ?
i have several relays from past partouts laying around, i just dont know which are which,
how many pins ?
what size relay case ?
thanks
how many pins ?
thanks
pINS
Has six pins straight accross is by the fuse box. Have seen the one on my wife car. But don't want to take things apart to get to it.
Engine: 4.3L Z TBI
hum thats real interesting
got a pic ?
internet search ?
ill see what i can find out
got a pic ?
internet search ?
Relay
No Pics sorry. Only have the wire conector. Adding power door locks windows and mirrors and power seats. Will do a junk yard search this weekend. ANd see if I can find one.
Engine: 4.3L Z TBI
Re: Relay
i see
im not having much luck finding out anything so far yet
im basically 100% sure that this car im parting is a factory power lock car, it even has the correct rectangle cutout in the console top and everything,
unless GM changed their lock relays sometime in the later 80s away from the regular three spade ones ?
im really unsure if they may have, but i wouldnt think so
hmm
lemme know what you find out, as im always glad ot learn more trivial GM info
relay
According to the board. Did a search they changed the relay in 1988 to the one that I have. Go figure.
So updated post to 88-92 door lock relay
I could snag you one from the local junkyard if you're interested. There's an 89 RS in the yard with factory power locks. I wouldn't want much for it. Just shipping and a few bucks for the part itself. Let me know, Pat.
Dock Lock relay
Okay sounds good. Will email you a link to a picture of the relay. SO you know what to get.
Found oNe
Found one from another member on the board. So now I will buy some new window motors. Going to do the swap in march or april. When work slows down.
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
kurfbird -
Do you need anything else for your car? I am parting a '90 Formula which was rear-ended, and have a perfect car from basically the doors forward. One window is stuck, but I think the motors are fine and the window just is off it's track.
Lemme know if you're interested in anything.
KZad
KZad
1992 Trans Am
May 10, 2023 07:19 PM
