Parts Wanted 2006 Looking for something in particular? Ask here.
Need an oil pan!
Old Feb 14, 2006 | 07:28 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
Need an oil pan!
I need an oil pan for an SBC. needs to be 2 piece rear main seal, drivers side dipstick. No chrome pans. Must fit a thirdgen. Thanks!
Old Feb 14, 2006 | 07:31 PM
dave mc's Avatar
Car: 87gta 88gta 88marovert
I have one on a 92 305 that looks good. 30.00 bucks deliverd
Old Feb 14, 2006 | 10:11 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
if its a 92 305 its a 1 piee rear main seal and passenger side dipstick...unless the motor was swapped at one point. i have a pre 1980 block with the drivers side dipstick and 2 piece RMS...if the pan you have is the same way ill take it if its dent free.
Old Feb 14, 2006 | 10:35 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'll have to look but I thing the 85 Iroc I picked up still has the pan on it. I believe they went to the one piece rear in 86 so i will have to double check...........jt
Old Feb 15, 2006 | 11:49 AM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
yes the 85 will have a 2 piece pan on it, but it may be a passenger side dipstick
Old Feb 15, 2006 | 12:07 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
Monteman....I believe you are correct on the dipstick..if I am not mistken, the pass. side was 80+ and the drivers side was 55-79.
I too am looking for one and was looking at the one's from summit. They have a steel pan that will fit any sbc except 62-67 nova, etc.
I am thinking of getting that one for my 361 I am building for the 89RS....part number sum-g3500x.
Hope this helps you out some.
Mike
Old Feb 15, 2006 | 01:34 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
awesome, if it will fit our chassis and isnt too expensive ill look into it
Old Feb 15, 2006 | 01:39 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
I am checkin around on the fitment.... where it goes over the crossmember. If it does, I am buying it! It just talks about the nova and chevelle as far as fitment problems...its only $21.00!!!! so it is worth it....you can also get one powdercoated orange for a few bucks more.
Old Feb 15, 2006 | 02:17 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I have the exact pan with the exception that it has a larger sump. I had it on my 86 TA. I also have a high pressure oil pump with pick up attached specifically for the pan.
Old Feb 15, 2006 | 02:20 PM
Pat Hall's Avatar
I have several d.s. dipstick, 2-piece rms pans kicking around in my garage. I know for a fact that they fit 1st and 2nd gen F-bodies. Not sure if they fit a thirdgen, but I'm betting they do. I've never heard of anyone having to get a custom pan when they put an old school small block in a thirdgen. The only pans that would probably have any clearance issues would be the ones from trucks I would think. Let me know if you're interested in one. Pat.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
