B&M 144
Old Jun 21, 2010 | 01:35 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
B&M 144
Thought I'd post pics of my progress on my B&M 144 S/c on my l69.
Attached Thumbnails B&M 144-sspx0076.jpg   B&M 144-sspx0077.jpg   B&M 144-sspx0078.jpg
Old Jun 21, 2010 | 02:03 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
Btw this combo is a l69 305, with 882 350 heads and a B&M 144 s/c. It should make roughly 8-9lbs of boost.
Old Jun 21, 2010 | 02:40 PM
Sutoto2189's Avatar
Car: '85 Iroc-Z, '03 Z71
Engine: Blown 383, 323 SBC
Transmission: 700r4, 4L60E
Axle/Gears: GU6 3.42, G80 3.73
Re: B&M 144
Got any idea of what kind of power you will be making? Im actualy looking into a Wieand 177 S/C for my 350.
Old Jun 21, 2010 | 03:14 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
Someone told me 350ish crank hp. I'll definitely have it dynoed here in the next month or two. It's hard to tell tho. I'm hoping to have it finished by thursday.
Old Jun 21, 2010 | 05:44 PM
Damon's Avatar
Re: B&M 144
Very nice. Looking good.
BTW- 4" cowl hood minimum on a 3rd gen with a 142/144 mini-blower. 2" cowl hood will be too tight to squeeze a reasonably sized air cleaner under.
Old Jun 21, 2010 | 09:06 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
I got it all to fit with a harwood pin on 3 inch and edelbrock drop base with 3inch filter.
Old Jun 22, 2010 | 06:00 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: B&M 144
Originally Posted by Ivelostcontact
I got it all to fit with a harwood pin on 3 inch and edelbrock drop base with 3inch filter....
Do you have any pics w/the hood closed from the drivers seat? Thought about doing something similar awhile back, but hood clearance always seemed to deter me though. Thanks....
Old Jun 23, 2010 | 08:19 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: B&M 144
I thought the 142 was the "low profile" version and would have the best chance of fitting under a 3" cowl...guess not. Lookin good! I like how you've kept your AC...I would have too if mine worked.
I can't tell...are you still runing the CCC system with it? Always wondered if it would work well with a blower or not. After all, it does have a knock sensor to automatically back down the timing if it starts to ping.
I'd like to think you'll get more than 350 crank HP with 8 pounds of boost. The torqe numbers should be good too. Either way - nice.
Old Jun 24, 2010 | 06:02 AM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
Yeah, having starting issues at the moment. Was finishing up last night in the dark. Been busy all week. Probably mixed up the plug wires. I'm gonna work some more on it today. It's an after market holley street avenger 670. I believe the CCCs will work too. The 144 is the low profile.
Old Jun 24, 2010 | 05:14 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
She's done. Couple little things to tweak like more timing and rocker arm pecking, but runs beautifully. Definitely a stronger car from what I can tell.
Old Jul 3, 2010 | 11:29 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
Re: B&M 144
How does your car run. What is your combo I'm looking building a s/c 350. but dont want a gas eater
Old Jan 29, 2011 | 12:30 AM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
forgot about this thread due to lack of progress. The car ran good at 5lbs of boost. From what i could tell my gas milage didn't suffer, but i was already running a bigger than needed carb to begin with. Still averaged 14-16 mpg a tank. I put a 9lb boost pulley on and it ran good about twice until i had a radiator hose blow out, over heated, and blew the head gasket along with my hydraulic clutch line blowing out the same day. I replaced the head gaskets and clutch line only to somehow break my slave cylinded when i removed my drivers side long tube. replaced that with a new one. pressed the clutch in and blew out the clutch master cylinder. lol. I said screw it till it warms up. i'm at work for 11 more days. i'll probably go home and replace the master cylinder and then i'll start posting more progress. i will say this, at 5lbs boost and stock timing it gave my buddies ls1 vette a good run to 75ish mph.
Old Jan 30, 2011 | 03:05 PM
Axle/Gears: 3.08
Re: B&M 144
Did you ever get it dyno.
Old Jan 30, 2011 | 04:25 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: B&M 144
na, not yet. I'm not even sure where the closest dyno is to Huntington, W.V. judging by the vette i raced at 5psi i'd say 320-340ish
Old Feb 1, 2011 | 02:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: B&M 144
Hmmm...I wonder. My original 305HO (L69) is sitting on a stand with only around 3K on a fresh rebuild...
Magnacharged 305? lol
Old Jul 14, 2018 | 09:35 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: B&M 144
Curious what hood did you end up going with?
JSDaddy189
Sep 26, 2015 03:50 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Grumpy
24
Apr 30, 2004 08:36 PM
a73camaro
Jul 31, 2003 05:07 PM
Grumpy
Jun 9, 2003 06:05 AM
