Final F1R mockup pics
Old Apr 16, 2002 | 06:57 PM
Blown406bird's Avatar
First one
Old Apr 16, 2002 | 06:59 PM
second
Old Apr 16, 2002 | 07:04 PM
Looks like the Alt will be relocated on the drivers side.
Old Apr 16, 2002 | 07:05 PM
maniacc's Avatar
Damn, that is one serious bracket, looks like you'll have flexing problems,
Looks awesome man!!!
larry
Old Apr 16, 2002 | 08:29 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Man I have now got the biggest wood ever!!
Old Apr 16, 2002 | 11:17 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Not compared to me you don't
Where did you get the bracket from? Did ATI supply it or did you have to go else where?
Regards
Robert
Old Apr 16, 2002 | 11:24 PM
Guido's Avatar
Car: 2000 Trans Am
Behemoth!
Freak!
Damn dats a big blowa!!
Looking good bro!
Old Apr 16, 2002 | 11:27 PM
89ProchargedROC's Avatar
ummm......mine's smaller but i have two of them
Old Apr 17, 2002 | 12:15 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
over and under or side by side?.......
and Im over the line
Old Apr 17, 2002 | 10:00 AM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
Good looking setup!
Old Apr 17, 2002 | 01:46 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Very sweet Tory.
Tim
Old Apr 17, 2002 | 03:31 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Now that is one HUUUUUUUUGE friggin blower. I believe he custom made the brackets btw.
Old Apr 17, 2002 | 04:07 PM
that bracket isn't custom made, ATI supplied it
Old Apr 17, 2002 | 04:22 PM
Saleen201's Avatar
Car: 1997 Mustang Saleen S281
hey how much did that thing cost? i want to build up a 350 or 383 with forged internals and want to go forced induction. Thanks
Mike
BTW...i see you live in Newark...i live in Dover...do you ever go to delmar race? i go every now and then.
Old Apr 17, 2002 | 05:00 PM
RacinLT1's Avatar
Saleen,i live about 5 mins from Blown406 and we dont go to Delmar. We usually run at cecil co MD.
I cant speak for price......but i can say that blower is flat out WICKED in person....
Old Apr 17, 2002 | 07:22 PM
Thanks guys.
The Bracket is a custom unit designed by Larry at ASSC and produced by ATI. It is basically a renegade setup. No PS or AC and you have to run an Electric water pump. The alternator also needs to be relocated to the drivers side with a low mount bracket.
This setup is not cheap by any means and is meant for a heavly modified engine. You have to pay to play.
I hope to make some decent HP figures with this setup and make all of us third geners proud to own one of these cars.
Old Apr 19, 2002 | 03:17 PM
JeffT's Avatar
Car: 1991 Z28
Damn, very impressive.
Couple of questions though. Why no ac? Is it a pulley alignment issue due to the cogs or something else??? Also, do you plan on using an intercooler? If so, what are you going to do about plumbing considering your discharge location doesn't appear to be ideal. Thanks for any info.
Old Apr 19, 2002 | 04:33 PM
TRAXION's Avatar
Tory ... AC .... rofl .... bwahaha ahahaha .....
Tim
Old Apr 19, 2002 | 08:32 PM
RacinLT1's Avatar
I cant remember the last time that car HAD ac. the pulleys are a "short water pump" style setup............if you got really creative,you might be able to hang an old style ac compressor and get it wo work. Most ac setups used the "long water pump" style pullies.
Old Apr 20, 2002 | 12:40 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Originally posted by Blown406bird
Thanks guys.
I was curious about that because when I started asking Procharger about that blower they started saying things like "I think...you grind the block and or....modify the strut tower." I am now curious; 1) did you have to do either of those things? and 2) do you think the outer housing could be reclocked to facilitate usage of the kit style intercooler? I was satisfied thinking I could fit my needs with the regular F-1 on a D-1 kit bracket and really just crank the thing up, now you have really got us thinking about that bigger mother for the 415.
Old Apr 20, 2002 | 12:53 AM
87Z-ya's Avatar
They dont make a kit style intercooler for third gens that will support that blower. They do have "universal" ones though
Old Apr 20, 2002 | 12:57 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I guess you misunderstood what I was asking.
Old Jan 8, 2003 | 01:40 PM
Daddyo's Avatar
Hi, I'm from over at CZ28.com and I've been asking questions over there about a F-IR install and the only problems I ran into is the bracket. 89prochargedroc let me know about your set-up and I have to say it is bad a$$ and is just what I was looking for. Now you say ASSC made it ,but you bought it from ATI is that right ? Now a new question comes up for me. You have a Dart little M correct? I have a LT-1 but plan or getting a GMPP block later on. Now heres the question are the bolt holes in the same location on both blocks? So I won't have to get a new bracket when I switch to the new motor. Thanks for your help in advance.
Thanks,
Johnny
Old Jan 8, 2003 | 02:33 PM
Guido's Avatar
Car: 2000 Trans Am
Hey johnny!
I think all the bolt holes are the same between the two blocks. As long as you get heads that are pre drilled for accessories.
Old Jan 9, 2003 | 08:15 AM
Daddyo's Avatar
Thanks, I don't think the heads will be a problem. Just found out that the bracket was a custom made pc. for his set-up. If I just knew what type of aluminum they use I can make my own.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
buckshot63
Sep 10, 2015 09:15 AM
gt4373
Sep 9, 2015 10:29 AM
