Everyone post pics of your power adder.
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Re: Everyone post pics of your power adder.
Yep, they are, 2 sets of the Corvette 18x9.5 rears, 275 front, 295 rear
The install and remove process is down to 40 minutes and 17 documented steps to go from NA to SC or back. (I've had the supercharger on and off too many times, hehehe)
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Addition of a stand alone.......still trying to fiure out where to get a couple of spray bars to mount in the existing blower carb plate, then will figure out the solenoid position/plumbing.
not fully plumbed yet
Car: 1988 camaro sc
Engine: nasty 305 tbi,tba 632 big block
Transmission: built 700r4
Addition of a stand alone.......still trying to fiure out where to get a couple of spray bars to mount in the existingblower carb plate, then will figure out the solenoid position/plumbing.
Car: 1992 B4C 1LE
Car: 83Z28 HO
Transmission: G Force 5 speed
Holey Moley flrtin1 - I've said it before....that ride of yours is sick!! Awesome, just awesome.
EDIT: And that engine is quite impressive in your car too Twin_Turbo! I'd hate to think how much HP that thing is puttin down. Is that a water cooled intercooler sitting on top, and how much boost are you running??
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Car: '91 trans am cnvtble and '91 GTA
Engine: 305 and 355
Axle/Gears: stock
what does your Z28 run in the 1/4mi? Just curious, what do you tell people when they ask why didnt you just do the ls1 swap? I have a 355 in my GTA and when i tell people i want to procharge it people all discourage me but i do want to use it was a daily driver, so i am convinced on doing the swap. i love your setup though looks awesome!
Not nearly as impressive as some on here. But it is the first ZZ4 with a 144 blower on it so far. Have a 50 shot of Nitrous and Methanol kit going on as well. Updates when I'm done.
https://www.thirdgen.org/forums/powe...y-144-fit.html
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
the 144 is getting popular
anyways for us po' folk this is a experiment with parts found around the shop
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Now that mine is painted and looks decent under the hood, I might as well add it to this thread..
I know in this picture the distributor cover and hood latch panel are not on, but they usually are
Current specs below but I'm working on a forged bottom end 350 (zz3) with AFR heads to go in later this summer.
Car: 92 Z28
Engine: Boosted LSX
this is for my iroc, actually i should say its about 60% done now
pics of when i first got it nexto a 2L coke bottle for size and one after i painted the cover
Car: 89 iroc single turbo
Engine: 383sbc 76mm turbo 402ci ls 88mm (in
Transmission: tko500
Axle/Gears: 8.5 10 bolt 4.10 gear 28 spline axl
heh, stuff that you have sitting around is fair game? OK, here are some of my current favorites out of my collection, from left to right, H1E that I rebuilt and polished, HX40 (internally identical to the H1E, they're the same turbo basically), HX52 (this is a cool turbo, big compressor side and small turbine), HT3b (big monster):
In this one, 2 GT42's off detroit diesels (front left a little one, back middle, a big GTA4202) and another HX52:
I also have a few more HX's and couple of eaton blowers but don't have pictures of them... There's at least one pair of 60/.63 turbo coupe T3's floating around people from this board that started in my garage also...
I forgot, I have a bunch of NX stuff in the garage, as well as a couple of 15lb bottles:
Car: 1992 B4C 1LE
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
heres my new combo.. forged 355 4 bolt sbc gt45r turbo and the last one is the tko im fixing for my car
Here's my new setup, 402 CI lq9 l92 heads, blow thru carb, 88mm Turbo.
Startup vid
http://www.youtube.com/watch?v=7wJyY_5l4xM
Walk around vid
http://www.youtube.com/watch?v=eSl_Kswzlz4
5psi run
http://www.youtube.com/watch?v=tsRvi...eature=related
Startup vid
Walk around vid
5psi run
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
83 crossfire
genius with the nitrous everything fits well??
also how much for the turbo??? :P
Car: 87' Firebird Formula
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
My lil set up is not a sweet as some of these on this thread but here is my budget build V6.
My first turbo build.
new to the boards but im working on a 88 irocz w/ a 509 bb and just picked up a 88 mm gt 45r i will be posting pics soon enough but in the mean time if any one is lookin for a really big supercharger i have a paxton novi3000 not many are out there from what i hear . the barcode is all x's. i got the blower from jim @jdm in freehold nj (the guy that does the lightnings)the blower was featured in mm and ff . it was installed on jims f150 befor the supercharged lightnings came out. if any one would like more info u can email me @joe732215@yahoo.com
Omg Steve's car is incredible.... The interior is amazing, and I love the wheels. The color, the clean motor, all just flows together perfect.
My completed setup
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
cool cars guys
ok ok. sooooo...... my dad past away 6 years ago leaving me a 1987 gta trans am. has a procharger. my dads friend said every sence he put that SC on there he said that my pops had a overheating problem on the car. he also said he seen the headers cheery red hot!!! the car sat for atleast 5 years intill i got old enough to drive it. so i pulled it out of the garage where it sat for five years and got it running again. ps i was 12 when my dad died. im 18 now. i replaced the oil fixxed the sumit racing eletric fuel pump. ran it hard a few time to get the motor turning again sence it sat for so long. i had no problems with the car. only thing ws that if it sat running for to long it would start to gett hot. now i have a bigger problem. it sputs at a slow speed and wont go over like 30 mph. like idk how to explain it. what could my problem be. one guy said it could be my fuel fillter. whats my problem and what should i do. make the motor stock and keep it simple. or keep the charger on there and have a fast *** car. ps the guy that installed the procharger builds engins. thats it. my dads friend said hes not super charger smart. and he could have installed it wrong. sombody help me!!! ill have some pics of the set up sooooon!!
Car: 1992 B4C 1LE
i never did get the t6 turbo on my car, i changed my mind before i got the hotside done and decided to go with a pair of 57mm turbos instead
these will flow enough to make 1,100 crank hp and i have full intentions to push them to there limit along with the 2 statges of nitrous backing them up
4 bolt main block punched .030 over
forged crank
good rods and bolts
forged pistons 9.2-1 cr
summit 224/224 cam
slightly ported tpi
megasquirt 2 v3.0 with ms2 extra code with antilag and nitrous control
nitrous oxide systems , 2 stage nozzle kit controled by the ms ecm 25hp first stage additional 75hp on the second stage
working on getting the 4l80 trans in the car now
the replacement motor for this one is a afr headed 434ci sbc this car is headed out to the boneville salt flats later this year if i can complete the cage and get suspension done in time
forged crank
good rods and bolts
summit 224/224 cam
slightly ported tpi
Car: 1991 Camaro RS
Beautiful Daverr
Heres a newer pic of mine with the alky and log headers. Nothing compared to most but its a fun fast V6 on a budget.
Car: 1987 Pontiac TransAm GTA
Engine: Vortech S-Trim, 355cid
Axle/Gears: Mosier 12bolt, 3:73 Eaton locker
Here's an old pic, need to get some new ones...
