Switching NOS and NX parts
Old May 7, 2002 | 07:54 PM
BenDoe91z28's Avatar
I'll make this quick and to the point. Can i use the NX bottle heater on my NOS kit? Can i use a NX bottle opener on my NOS kit? should i sell my NOS kit and get an NX kit?
Old May 8, 2002 | 12:04 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Yes. Yes. Yes.
Old May 8, 2002 | 01:41 AM
I just read that NX injects nitrous into the intake tubing.. is this true? Here's another quickie... how do you get fuel to the fuel solenoids, do I "T" with the main line?
Old May 8, 2002 | 06:27 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
pardon the dirty engine bay
But, to get the fuel to the solenoid, you run it from the test port on the fuel rail...
Old May 8, 2002 | 08:29 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
The NX kit includes a cool little "nut and bolt" if you could imagine it that they are kind of short and fat. They are made of aluminum and are made to hold a standard fogger nozzle in a hole in the intake tract. Bolt part comes from the inside and has a 1/8" NPT hole down the center for threading the fogger nozzle into (see above picture) this hold the nozzle facing into the engine, so it cant spin and spray against the side or backwards. This also makes it safer against nozzle "fallout/pullout" where the nozzle lays against your header waiting for you to hit it so it can spray the mixture onto your hot headers. Instant Camaro flambé! The fuel fitting fits onto your fuel pressure test port. The fitting for the fuel supply line is –4 and when you remove the Schrader valve stem core it will allow fuel to come out and you screw the –4 line on there. Only some cars have to cut and tap into the fuel line with these NX single nozzle wet systems, most Fords and GM’s do not have to.
Old May 8, 2002 | 08:34 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I'm about 99.9% positive that all GM EFI cars have the -4an test port for fuel.. The NX 20920 kit is said to work on every EFI car from GM, but I'm sure there is an exception..
Old May 8, 2002 | 08:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that is correct with 99.9% of that remaining .1% usually being TBI
Old May 8, 2002 | 08:38 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
yeah, I don't know very much about TBIs.. so I can't comment there
Old May 8, 2002 | 03:04 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
Sell NOS get NX install and be happy
Old May 8, 2002 | 09:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
i dont think you can use an NX bottle opener on a NOS bottle. I may be wrong but I could swear I read that somewhere.
Old May 9, 2002 | 07:23 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Yeah, you're wrong. the nx bottle opener works on all bottles...
The Nitrous Express "Next Generation"
remote bottle opener. The NX remote
opener is guaranteed not to affect
horsepower output or cause the
surging sensation associated with
current designs It is furnished with
all installation hardware and weather
pack wiring kit.
(fits any brand nitrous system).
Old May 9, 2002 | 07:58 AM
onebinky's Avatar
Yeah, no -4an test port for us
Old May 9, 2002 | 11:40 PM
Omar's Avatar
Half right. There are 2 versions. One for just NX bottles, and a universal one.
Old May 10, 2002 | 08:19 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here is that nozzle and intake tube bushing included in the kit
Old May 20, 2002 | 08:33 AM
gtabadboy's Avatar
FWHP vs. RWHP
Whats the difference between being rated at FWHP and RWHP? Whats better? I dont know if I should get NOS or NX.
Old May 20, 2002 | 10:45 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
rwhp == rear wheel hp, fwhp == fly wheel hp.
with a NOS kit rated at 100fwhp, you will get 100 to the flywheel, with losing 20% (or whatever your drivetrain loss % is.. 20 is just an arbitray #) with the NX kit rated at 100 rwhp, you will get 100 horsepower to the rear, with 124 or so to the flywheel..
Old May 20, 2002 | 06:39 PM
gtabadboy's Avatar
O OK. Thank you for the response. I think I will go with NX then. Another question, Can i run nitrous with hypereutectic pistons??
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
