Total Seal Rings and N2O
I know it is not recommended, but has anyone tried running a mild shot of Nitrous Oxide (75 - 100 HP) while utilizing Total Seal's "gapless" rings? If anyone has attempted this, did your piston rings hold up to the extra cylinder pressure????? :nono: :nono:
Car: 1992 B4C 1LE
First let me start out by saying that I think those rings are great, but there is a documented tendancy on boosted or juiced applications of cylinder pressure building between the rings faster than it can vent out causing a pressure that pushes up on the top ring and down on the bottom ring. At the least what you get is a distorted ring land at worst you get a piston that siezes in the bore from ring lock similar to an undergapped set of rings and any kind of ring lock can be catastrophic. here is a picture of our results (we didnt belive them ) we foundout for ourselves.
Car: 1992 B4C 1LE
Originally posted by Cary3982
Thanks for the info, Tom.
A picture is worth a thousand words!
Car: 1992 B4C 1LE
Hey Tom,
How big of a shot of juice was being fed to this mill when things got ugly???????
Hey Tom,
Car: 84z28
Engine: chevy 388
DARCOM
i have c&a gapless rings and i run boost and nos and have had no problems yet but i did gap the second ring alot and have my
pistons coated on top to reflect heat.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
