LT4 - add a blower or add NOS ?
Old Aug 19, 2002 | 09:57 PM
logikal6785's Avatar
well i have a new idea now. if i were to run a mildly tuned super on this engine (on the right, LT4 style) what kind of hp increase could i expect @ something low like 6-8 #'s of boost ?
what parts would i have to replace though, if it's straight out of the box it should be strong enough already ? is the LT4 straining to push those 429 hp bc i'd like to hit 600 but even 550 would be great.
or, on the other hand, would it be more cost effective to buy that crated LT4 engine and just have a cheater shot of NOS @ about 100hp or 125hp to spray for dragging or when i'm falling behind ? i've been searching and unless i steal a new buick and rip the SC off i don't think i can get one for less than 3K
Old Aug 20, 2002 | 04:24 AM
... come on tek gods =D
Old Aug 20, 2002 | 12:51 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I know the one one the left is a 10. somethin : 1 but do the LT4's heads make it even higher?
Old Aug 20, 2002 | 06:13 PM
zepher says his 54cc LT4 heads are making it a 10.8:1 bc the 58cc LT1 were 10:1
Old Aug 20, 2002 | 06:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
LT1 is 10.4, LT4 is 10.8 , ported stock LT1 heads will flow more than unported heads, something to consider.
Old Aug 20, 2002 | 08:48 PM
and if i had the lt4 heads ported ?
Old Aug 21, 2002 | 04:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you mean opening up the chaimbers?
Old Aug 21, 2002 | 04:57 PM
ya, to take it to 355 and putting high flow heads in for the LT4
Old Aug 21, 2002 | 08:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
how do you take it from 350 to 355 by opening up the chambers? explain this to me. is that kind of like stroking a motor by putting longer rods in it?
Old Aug 21, 2002 | 09:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yeah they'll get better numbers on the LT4 when both are ported, but look into getting the heads, and then porting etc and it really starts to add up, dont be surprised if you end up dropping 3k total for some ported LT4's by the time your done, not to mention, how do you plan to go about bolting up a blower ?
Old Aug 21, 2002 | 10:10 PM
well the S/C is out for now, see why here
are you serious though that i'm looking at 3K just to get the heads ported and polished ? b/c if u are then i'm just going to juice it and hold back for the s/c and an install somehow.
Old Aug 21, 2002 | 11:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Heh i've already got that solved, two soloutions....
1. There is a powerdyne kit for the 94-96 LT1 impala, it mounts the blower in almost the same spot as the tpi kits, not sure if you could put their gear driven in it, but its possible...
2. Use either a manual rack kit from PA with the tubular K member, or they can put the 4th gen rack mounts on it to retain power steering and use any of the f body kits you want.
Old Aug 23, 2002 | 10:48 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is what I plan on installing on my LT4,
Old Aug 23, 2002 | 11:48 AM
om ... i bet that'll feel good to hit the button on. can't wait to set mine up so don't tease me like this
Old Aug 23, 2002 | 11:49 AM
one quick Q - why are two foggers pink and two foggers blue ? were you painting the blue ones ?
Old Aug 23, 2002 | 12:00 PM
Zepher's Avatar
One pair of solenoids are for the fuel and the other 2 are for the nitrous. Blue is Nitrous and Red is Fuel.
Here is a wide shot of most of the stuff,
My heads are in those boxes,
Old Aug 23, 2002 | 04:57 PM
1982chevycamaroz28's Avatar
hey thats the same size bottle i got sitting in my room for my plate system i hope to install soon i hope. i can adjust my set up to a 250hjp shot but ill never go about 125-150 until i get fordge internales.
Old Aug 23, 2002 | 06:43 PM
are the heads stock LT4 or did you have them ported? and, not to be rude, but how much $ did it cost for what you got?
Old Aug 24, 2002 | 03:26 AM
Zepher's Avatar
Heads are stock LT4's with some bowl work done to them.
Here is the price breakdown for the buildup so far,
Complete LT1- $1,000
LT4 Heads and LT4 Intake- $850
NOS Direct Port Fogger Setup- Traded my entire exhuast for this, headers to exhaust tips.
Comp Cams Pro Magnum Rockers- $150
LT4 Hot Cam- Traded my SLP Dual CAI for it.
O2 Sensors- $40
A/C Delete Pulley- $40
30lbs Injectors- $100
Adjustable Fuel Pressure Regulator- $25
Manley Guide Plates- $15
I guess that is about all I have purchased so far.
Still need a few more items though.
Another $3000 or so and my car will be on the road.
Old Aug 24, 2002 | 05:05 AM
wow. i assume that a few of those parts left to get include forged internals if you're going to run a 200 shot ?
*no edit, just remembered - "wow" is precisely what my gf said after the car spun at 85 and jumped the curb sideways at 55. that's a hell of an engine is what i meant to say
Old Aug 24, 2002 | 11:58 AM
Zepher's Avatar
I may just go with a smaller shot for this motor and build up a 383 forged shortblock and then swap all the upper parts onto that in the future.
There are so many parts that I want to buy for the car, I'll probably have $25K+ into the car when I am competely done and satisfied. It will take a long time to get it the way I want it.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
