Is my Fuel Pump large enough?
Old Aug 23, 2002 | 11:02 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am running a Holley 255lph in-line pump on my car.
It will have an LT4 with a 150-200hp Fogger setup.
Just want to know if I will need to add another fuel pump.
Here is the Kit I have,
Old Aug 24, 2002 | 07:51 PM
1982chevycamaroz28's Avatar
id say run another electric pump i guess u could call it inline. but just acctach another pump to the fuel line close to the engine or engine bay so that it would keep the fuel pressure thats coming out of the pump in the tank. im not to sure about this. i know someone else knows but im just taking a stab at it.
Old Aug 25, 2002 | 02:03 AM
Zepher's Avatar
My fuel pump on my car right now is an external in-line pump.
Old Aug 25, 2002 | 02:49 AM
True Power's Avatar
You can always put in another inline. It's not impossible
Old Aug 25, 2002 | 05:27 AM
logikal6785's Avatar
possible but is it advisable/necessary for maintaining the pressure? i mean i know these cars are long ( try shimmying under one with no roller-pad to slide ... i swear it's a mile from the front bumper to where the shifter-cable bolts to the gear selector on the 700r4 ) but can they lose that much pressure between the pump and the heads ?
Old Aug 25, 2002 | 04:05 PM
Zepher's Avatar
One alternative would be to add a second pump and hook it directly to the NOS Fuel Solenoids so that they get thier own fuel supply. That should work, right?
Old Aug 26, 2002 | 11:05 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Yes. I know a guy that has a separate 5gal cell he fills w/ cam2. He run 93 in his gas tank. There's a separate line going from the cell to the fuel solenoids.
Old Aug 26, 2002 | 11:54 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
running a separate pump, regulator and 1 gal fuel cell like this?
Attached Thumbnails Is my Fuel Pump large enough?-fuelcell_finished-above.jpg
Old Aug 26, 2002 | 03:38 PM
Zepher's Avatar
That setup looks sweet. Where is that located? and is it in a Firebird?
Old Aug 26, 2002 | 03:57 PM
DABE's Avatar
is that teflon tape on the fittings??....if so it will clog the solenoids...just a heads up...
DABE
Old Aug 26, 2002 | 04:03 PM
Zepher's Avatar
DABE
Yep, that is teflon tape and it is coming off. A friend told me saturday to use teflon paste or something like that since the tape can clog or make the solenoids stick open.
Oh, and the tape was on it when I got it. It wasn't ran with the tape on the solenoids, so I should be fine once I remove the tape.
Old Aug 26, 2002 | 04:07 PM
DABE's Avatar
ok....just checkin up...didnt want to to mess up your solenoids...
Also do the same with the gauge..
Theres something that makes the teflon tape break apart....but...the paste is good...
DABE
Old Aug 27, 2002 | 03:35 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
teflon paste is good, very good. Unless you use too much and use it where no sealant is needed like this dip I took pictures of did.
Old Aug 28, 2002 | 12:19 AM
89ProchargedROC's Avatar
LOL, paste on AN fittings huh?
smart guy
Old Aug 28, 2002 | 08:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
maybe he thought he was goanna brush his teeth with it "Crest with MSP (Maximum Stupidity Protection)"
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
