Nitroused track times...slow?
Old Sep 11, 2002 | 10:17 PM
MelloYello's Avatar
I ran my car at the track for the first time since the NX install.
With the 150 shot along with the mods in my sig:
60'......1.981
330'....5.483
1/8.....8.380
MPH....84.80
1000'..10.875
1/4.....12.982
MPH....109.25
What do you guys think? I think that's a little slow for that much spray. I hit nitrous at the beginning of second gear on this run. I tried to hit it in first but I ran slower: 13.3@106 (plus I think my bottle is near empty now. I checked my fuel pressure and its set at 44 psi, but I think that's still too rich. I am using 62 Nitrous/35 fuel. You help is greatly appreciated.
Kyle
Old Sep 12, 2002 | 10:47 PM
MelloYello's Avatar
omfg some advice plz...ttt
Old Sep 13, 2002 | 03:36 AM
Chris Ja's Avatar
If your car is running around 14.4 off the bottle then it would be about right. Also how much traction did you get. Need more information. What was bottle pressure. Are you heating the bottle ect?
Old Sep 13, 2002 | 03:50 AM
bjm323's Avatar
Car: '91 Camaro RS
What makes you think you are running too rich on the nitrous?? Do you know how to read a sparkplug correctly? It is better to be a little rich than lean. Like Chris said, you need to provide alot more information.
Old Sep 13, 2002 | 09:24 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Make sure you have a bottle heater and currect psi, also do you purge at all???
Old Sep 14, 2002 | 01:50 PM
MelloYello's Avatar
I have the fully automatic bottle heater that comes with NX GenX-2 kit. It heats the bottle based upon bottle pressure - Nitrous was a constant 1000psi (not sure about throughout the run, though. I have a purge and I purged the Nitrous to make sure my engine was recieving liquid nitrous. My nozzle is about 7 inches in front of the throttlebody. On my second pass, however, I only clicked off a 13.3@105 mph - bottle near empty. Could it be that I was getting air in the lines along with the nitrous on the 12.9 run?
I am going to dyno tune my car with the Nitrous usig a wideband O2 on the 22nd. That should give me alot more horsepower and still allow me to remain safe.
P.S. Fuel Hiccups are not a concern, as I have a fuel pressure safety switch installed - My Nitrous will cut out if fp drops below 35 psi, but I will raise that limit to 40 psi.
Thanks again
Kyle
Old Sep 14, 2002 | 01:51 PM
MelloYello's Avatar
Oh yeah...I have that pass on video...so I guess I can digitize it and submit it to this site for all of you to see
Old Sep 14, 2002 | 02:16 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
well you seem to have everthing you need and used properly. After looking at your times again I think it is pretty accurate. Run it again with a full bottle and bet it will be a little better.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
