run a single 60mm turbo or twin two smaller ones?
one big turbo(60mm GN) or twin smaller turbos(t04)?
pros and cons in performance, not worried about fabrication. I only want to run 6-8 lbs boost. thanks
Car: 2000 Trans Am
twins will give you more low end punch and blow your tires away.
A single will take up less space. With a V8, you are not going to experience any noticable lag since there are 8 cylinder feeding it.
Id say 60mm since it gives you more room to change plugs and what not under the hood.
Good luck.
Good luck.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Does anyone know what numerical sizes say 88mm, or 60mm translates to? For instance, what mm size is a T-3, or T04? Anyone know?
Thanks,
Thanks,
Thanks,
Thanks,
T-3, T-4 turbos are 'styles' of turbos. They can have different wheels in them to suit different applications
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I heard the GN/TTA came with t3 turbos from the factory, but I could be wrong...
The larger turbos are denoted by size as their decription - T66 = 66mm, T72 = 72mm... There are a lot of different blade styles, blade pitches, and compressor housings to choose from. There is no generic T72 turbo.
I think that there are a few 60mm turbos available, but research before buying please.
