Turbo and compression
Old Oct 8, 2002 | 03:02 PM
ir0cflamez's Avatar
I'm currently running a blower with about 7.5psi on stock compression. (9:3).
Have any of the turbo guys here run their turbo(s) on the stock bottem? If so, how long did it last?
Eventually I know i will have to do a piston swap. Should I go flat and forged?
Old Oct 12, 2002 | 07:18 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
my motor has 8.0:1, stock pistons
i run around 17# on pump gas, once i get this thing tuned a bit better i'm sure i could squeeze another # before i get detontation
Old Oct 12, 2002 | 07:26 PM
Twin_Turbo's Avatar
I went to forged JE 22cc dished pistons. They're just too beautiful to install
Marck
Old Oct 14, 2002 | 12:32 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
My wife wont let me keep mine in the house either
Old Oct 14, 2002 | 05:34 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I've got JE's also with somewhere under 8:1(I'm thinking 7.6-7.8:1)and run 20-21#'s on 94 octane.
Steve
Old Oct 15, 2002 | 03:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
mine are 1.384" comp height dish top 4.155" dia bust out the calculator and guess what stroke/rod combo/CID it was made for he-he
Old Oct 16, 2002 | 11:18 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I was running my twin turbo setup on the stock L98 for 2 years. When I pulled the engine last winter, I tore it apart, and nothing was wrong. All the ring lands were in one piece, cylinder walls looked good, no cracking, etc. This was with 5 psi non-intercooled and 8 psi intercooled. As long as you make sure to *never* get detonation, you'll be fine. Run rich (11.5 to 12:1 or so) and conservative timing, and you'll be set for a while
The new engine will have custom JE pistons - 27.5 cc inverted dish, 1.151" compression height for a .038 quench, and 8.25:1 compression. max boost will be 25 psi
Andris
Old Oct 16, 2002 | 01:55 PM
89ProchargedROC's Avatar
I have TRW blower pistons with ported track 1 heads....i think its somewhere in the 8.0-8.2 range with a quench of .036-.039
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
