305 tbi nitrous help
I am thinking about putting on the nos setup on my 305 tbi but also want to add a performance chip to my car to get rid of the top speed limiter, and I have read that chips and nitrous dont mix is there a special chip I can use or do I have to custom burn my own chip.
Car: 1992 B4C 1LE
never heard of a 3rd gen with a speed limiter
yes it cuts me off at 115 like all other 305 tbi, which is why I hate this engine but I still want to mod it to see what they can do but would much rather have a 350 TPI. if anybody knows of a chip I can use let me know or should I just not use the nitrous.
Car: 1992 B4C 1LE
I have never had a TBI car and so never have seen a speed limiter
i would definitely get a new chip custom burnes, since from what i have seen, a lot of chips make you run lean for some reason. you DO NOT need a chip, though, if all you are doing is running nitrous. its not a requirement or anything.
Car: 1991 Camaro RS
Engine: 4 bbl 305
just cut the wire to the speed limiter they give you the diagram in the tech articles i did that to my car now its no more fuel cutoff hehehe
