I got lucky! got a turbo!
Old Oct 13, 2002 | 05:39 PM
no_car_yet's Avatar
I was rootin through the dump today and found a stack of cars. i popped the hood on a chrysler van i saw it said tubo. i got the turbo off it and its home now but what else will i need to hook it up to my firebird. I know i'll need a custom header, but thats no problem i just need to know how to get it working, or what else i need to get off the van. BTW; its a mitsubishi turbocharger.
Old Oct 13, 2002 | 06:30 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Your gonna need a second turbo. That little mitz is designed for a 2.2L, your 305 is way to large.
Old Oct 13, 2002 | 08:21 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
You definatly need a second turbo. Make sure to get an identical turbo, not something sized differently.
Old Oct 13, 2002 | 09:08 PM
no_car_yet's Avatar
what if i put it on my cavalier wagon 2.2 ahahah. I am not sure if i would really want to turbo my 305, i am afraid i might loose it. whats a safe psi setting go go with? Getting a second one wouldn't be too hard, but then i would make that one on the other side right?
Old Oct 13, 2002 | 10:09 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Owning a couple dodge daytona shelby Z's, from what I hear the mistu. turbos are much worse(not prefered) to the garrett turbos that came in those cars. I would say don't use it for you firebird at all regardless of set up.(may work in another 4 banger) Try www.thedodgegarage.com for more info about that turbo or any FWD dodge turbos.
Old Oct 14, 2002 | 02:39 AM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
A really good idea would be read the book "Maximum Boost" by Corky Bell. you should be ablke to get one used off amzon.com for under $20. It'll teach you how to read compressor maps and such, allowing you to decide if it will work for your 305.
Post some pics of the turbo if U can and someone should be able to tell you exactly what turbo it is. Chances are its a Garret T3 but you never know. A single T3 won't get it done on your 305 unless you plan to run 15+ lbs. of boost. Even then it wouldn't be a good idea.
Old Oct 14, 2002 | 06:59 AM
Twin_Turbo's Avatar
"A single T3 won't get it done on your 305 unless you plan to run 15+ lbs. of boost."
That doesn't make sense. If the single turbo is too small for the 305 you will never get it to produce 15psi of boost.
Old Oct 14, 2002 | 10:04 AM
no_car_yet's Avatar
its a mitsubishi turbo part TEO4H. it is quite small and right now runs 8 psi, but it can be turned up to about 15. I might not even put it on my 305, i might just sell it to some ***** and buy something else for my car. I have a 350 savings fund if anyone wants to donate, then i am putting a vortech supercharger on that!.
Old Oct 14, 2002 | 01:30 PM
1992_25t_1letpi's Avatar
won't work not good enough.
Old Oct 14, 2002 | 01:37 PM
Car: 86 Cutlass
Doesn't matter if you turn the boost up, its a compressor and its only going to flow so much air. If I were you, I'd sell it and save up for that supercharger.
Old Oct 15, 2002 | 04:28 AM
test
Old Oct 15, 2002 | 04:32 AM
no_car_yet's Avatar
i got 4 imports guys offering me 2-300 bucks so it is going today! I still find it pretty lucky i found them cause it was like winning that much money. I can smell a new camshaft already!
Hotrodboba400
Dec 10, 2019 07:07 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
