NON 3rd gen, but need help with nitrous install on a VW
Old Oct 23, 2002 | 09:54 AM
fattie92's Avatar
ok we put a Zex kit on my friends 91 VW Passat(4 banger). Since the Zex kit was intended for Hondas and the such, the instal didnt go as planed. a typical zex instal has a wire that goes to the TPS and senses WOT, but VW have a differant voltage at that wire then hondas and casue the nitrous to spray all the time....no big deal realy,, we ran wires from the battery, and the box to a switch inside the car, then ran a pushbutton off that to spray the nitrous (only 55 shot)...so we finaly get the install done, and go and test it... first time spraying went good. it was just a quick little spray with no ill effects....but when we tried to spray it after that it BOGS like a mother..then you get outside and it smells like its running extrmely rich. what do you make of this? and y did it run good for the first time? since its only a 55 shot, the timing shouldnt have to be retarded at all....any help?
Old Oct 23, 2002 | 12:06 PM
Bobalos's Avatar
sounds like the N2O solenoid is not opening up. disconnect the line from the jet, turn on the bottle & push your activation button (HOLD onto the line or it will go all over the place). you should see a TON of N2O coming out of the tube. if not............
BW
Old Oct 23, 2002 | 12:11 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Uh... ZEX's are like "solid state" and it is all housed inside a box
Old Oct 23, 2002 | 12:27 PM
fattie92's Avatar
i know nitrous is coming out. if you dont start the car and push the button, it will spray.
Old Oct 23, 2002 | 05:51 PM
fattie92's Avatar
ttt
Old Oct 23, 2002 | 06:14 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
My guess is that the TPS is something like 5volts at WOT and you hooked it up to the battery sending 12 volts to a input not designed for 12 volts and bet the box is toast..
Old Oct 23, 2002 | 06:24 PM
fattie92's Avatar
that is a interesting thought...ill look into that one.. but if that is the case, then the box should have ben fried a LONG time ago. we have tested that thing to a 12V source for days without problems(just listening to hear the selenoid to click)
1992rs/ss
Jan 31, 2025 05:10 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
reiderz iroc
Aug 13, 2015 04:57 PM
