guido!
Old Oct 29, 2002 | 08:10 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
guido!
I heard you made some kind of custom fuel inj. setup with a Edelbrock intake and some other stuff, im really interested in what you did and your numbers with it.....
dan
Old Oct 29, 2002 | 10:37 PM
Guido's Avatar
Car: 2000 Trans Am
Who told you about my car anyway? A guy named CD or Chris from Connersville? With a mustang?
Its not an edelbrock intake. its an accell intake with an elbow adapter on top of it.
the intake is a carb style intake with EFI bungs cast into it. I bought it like that and it came with the fuel rails.
As for performance, I havent got the car lined out yet. The one dyno pull ive gotten so far netted 512rwhp and resulted in tubes blowing off at the connection points. and the car was rich. I havent been able to get back to the dyno yet but I bet it will make 700-800rwhp.
Old Oct 29, 2002 | 11:26 PM
89ProchargedROC's Avatar
i did something like u were describing:
here
Old Oct 30, 2002 | 01:48 AM
NOSFEDGTA's Avatar
I have the same intake as guido for sale if you are interested. The one diff is that I run a 4bbl style throtle body instead of the elbow. I run NOS so I did not need the elbow. Let me know if you are interested..
her is a pic
Drew
Old Oct 30, 2002 | 03:21 AM
dans82bird's Avatar
Engine: 302
what kinda mpg can I get with something like that on a 400 some odd hp 350? what kinda efi control do you use and also how much $
Old Oct 30, 2002 | 01:21 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I am interested too tell me tell me! and what else does it come with injectors / throttle body what what
Kingtal0n@aol.com
Old Oct 30, 2002 | 08:59 PM
NOSFEDGTA's Avatar
Here is a list of everything it comes with and waht I am asking.
1: Accell Pro Ram intake
2: Billett Fuel Rails
3: All -6an Fittings
4: -6an Braided stainless Steel cross over lines
5: SX ADJ regulator with -6 AN fittins for feed and return.
6: Billett 1000cfm 4bbl style Throttle Body with Iac and TPS sensors and harness adapters
7: 30lb SVO Injectors
8: Intake is Port Matched To my AFR 210 Heads
9: Coolant temp sensor
10: IAT Sensor
I have alot of cash in this intake. I am only askign 1250.00 for everything! I need to get rid of this setup asap. That is why I am only asking 1250.00 I have more than that into the intake,rails, and throttle body.
Old Oct 31, 2002 | 01:19 AM
BlownBird's Avatar
Send me an e-mail...
I am interested in the throttle body, and would like to know if you are willing to part this out. Let me know, Don B.
Old Oct 31, 2002 | 01:54 AM
NOSFEDGTA's Avatar
It seems I have a few people interested in different parts from my setup. I would like to sell it whole, but If I can part it out thats fine as well. I have e-mailed Don on the throttle body as well as each of you individually. If you guys can e-mail me and tell me what you are interested in specifically then maybe I can part out the whole thing and everyone can get what parts they want. E-mail me asap with what you are interested in.
Drew
Old Oct 31, 2002 | 10:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what size intake port gasket would that fit? if it is the larger 1206/1207, then did they come pretty close to that size or did it require a weld/port job?
Old Oct 31, 2002 | 05:06 PM
NOSFEDGTA's Avatar
It was a 1206, but htey were not close at all. Almost an 1/8 of an inch...
Drew
Old Oct 31, 2002 | 07:01 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
so you just ported the material out nicely or you had to add some?
Old Nov 2, 2002 | 10:43 AM
NOSFEDGTA's Avatar
The people at coupe performance did not have to add any material. The did an great job on the intake too. The just port matched it to the gasket as well as the head to the gasket.
Drew
Old Nov 5, 2002 | 11:21 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
10: IAT Sensor
Is this this available?
Old Nov 6, 2002 | 12:06 AM
NOSFEDGTA's Avatar
It was untill yestereday
Old Nov 6, 2002 | 01:01 AM
Car: 89 Formula
Engine: Nada - v4.0
Suxs being us then huh?
Old Nov 6, 2002 | 07:18 AM
Guido's Avatar
Car: 2000 Trans Am
LOL
I thought you had that setup already?
Old Nov 6, 2002 | 12:14 PM
NOSFEDGTA's Avatar
If the deal falls through, you will be first on my list....
Drew
Old Nov 7, 2002 | 12:04 AM
Car: 89 Formula
Engine: Nada - v4.0
Can't a guy have a spare???
Seriously, I do and I LOVE IT. Best thing I ever did was dumping my StupidRam and buying this setup. But the 406 we're going to stick in the 66 Nova my brother just bought doesn't have one.
Guido
Dec 28, 2001 04:31 PM
Guido
Dec 12, 2001 01:20 PM
Guido
Nov 25, 2001 09:54 PM
Guido
Nov 1, 2001 08:59 PM
Guido
Aftermarket Product Review
Sep 29, 2000 07:50 PM
