Nitrous & S/C?
Old Nov 3, 2002 | 02:06 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
Nitrous & S/C?
I have an ATI charger at 9spi on my 383, hypeeutectic pistons, i am interested in running nitrous next spring/summer, i was told by a guy that whatever HP shot i get, its doubled on a boosted car, I.E. 50hp would be 100 on my car because of the blower, is this true? and will i have any problems wwiht running both nos and my charger? i plan on getting boost retard, colder plugs and running good gas when i spray. any suggestions/comments for me? im new in the nitrous world.
Old Nov 3, 2002 | 02:10 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont think the 50 will be 100 but I say "go for it", what the heck its only metal right?
Old Nov 3, 2002 | 02:18 PM
87transam5.7tpi's Avatar
I'll be running about the same setup next summer. Superram on a 355, all forged internals, S/C w/ a 150 shot of nitrous. I hope to hit 9.99 in the 1/4 with everything. so I'd say go for it so I'll know if I can do it
Old Nov 3, 2002 | 02:36 PM
gflo383's Avatar
Car: IROC Z
if i do install NOS, what could happen: bent rod...not tooo bad, hole in piston, not tooo bad, broken rod, ok gettin there. broken rod, shatterd piston and hole in side of block and a broken crank...ok thats it, that is pretty bad, but realisticaly, i doubt the worst would happen, and if it did, its just an opportunity to UPRGRADE! he he he
Old Nov 3, 2002 | 03:20 PM
92camaro's Avatar
With two poweradders on a car it is going to be very hard to tune and gett running correctly with out blowing something up. I think I would hold off on the nitrous until you built a stronger bottem end or aleast forged pistons. What kind of times does your car run?
Old Nov 9, 2002 | 10:15 AM
TBI305Camaro's Avatar
I know a guy with a 2.0 plymouth laser running a turbo and nitrous on his bottom end. Im not sure what the boost is on the turbo or how much n2o but i have seen that laser outrun a mustang GT with a 9 psi paxton...how can a car lkike that get away with it.
Old Nov 9, 2002 | 10:58 AM
92camaro's Avatar
Most turbo cars have turbo lag. They use nitrous to help them out of the hole until the turbo spools up then they let out of the nitrous. On a blower car you don't have any lag. If you want to use nitrous then go for it but I would only use a very small shot like a 25 or 30 just to cool the air down. I have a blown mustang that runs 8.60-8.70 @155+ and it seem like the tune changes on that thing everytime I bring it out. And I would hate to try to tune two poweradders.
Old Nov 9, 2002 | 01:26 PM
vortechLT1's Avatar
running a very small dose of n2o would be smart (unless you have all forged internals) since a nitrous system would theareticlly be the perfect compliment to a S/C or turbo because its so cold,
I have a Book called the pros and cons of power adders, it tells what should be done when using multiple power adders and how to properly tune them and also has a chapter that describes what has been proven to work and what has failed
if I can dig it out (its in storage) I will transfer it on the computer and post it on the boards
Old Nov 11, 2002 | 03:32 PM
Damon's Avatar
My expereince is that adding N2O to a blown motor will have only slightly more effect than adding it to a N/A motor. This comes from the fact that the N2O is basically a chemical intercooler, which can help your blower's efficiency a little. It's definitely nothing like a 2:1 ratio, though.
I plan on adding a little tickof the stuff (100HP) to my Malibu next summer. STILL on cast pistons and crank.
Old Nov 12, 2002 | 10:14 AM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Nitrous & S/C?
[QUOTE]Originally posted by gflo383
[B] hypereutectic pistons,QUOTE]
I don't think I'd want boost AND juice on a set of those babies. And yes in a forced induction car nitrous will yield almost 2:1 results.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
bad camaro RS
Aftermarket Product Review
Feb 26, 2001 01:33 PM
