pics of Nitrous switches
Car: 89 Firebird
some where out of sight.. cops seem to have the feeling that NOS is a big :nono:
or if you don't care about them, then i'd go for the easiest place it is to hit them
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Mine are in my console right behind the window switchs. The switch are from NX, the first one rocks both ways. Arms the system and turns on the bottle heater. The second is a spring loaded rocker for the purge. The tird is for the remote bottle opener.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Mine are in the ashtray. Out of site and out of mind.
The purge, arming, and bottle heater fit rather nicely once you remove the metal part of the ashtray.
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Here in MA the law is that you may not transport nitrous unless you are traveling to or from a race venue and the system is disabled. If you are going to transport it otherwise you have to have one of those big ugly "Nitrous Oxidide" and "Unflammable" signs on your vehicle.
Like I said.... thats what the law.... if it is ever enforced I think it is up to the officer at the time. Mine switches are in an easy to hit location.
Car: 1992 B4C 1LE
Nebraska tried to get a scarlet letter law just like Massivetwo****s.
Engine: 355
Axle/Gears: 4.11
Originally posted by N8Miller
do you have any pics of this?
I plan on hidding the rest under the hood and putting the WOT switch under the gass pedal.
Car: 1992 B4C 1LE
I need to take a pic of mine, but unless the wife got me a dig cam for Xmas or I borrow one....The switch is a NOS one right between the TB and the TPS.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
i know of a aftermarket shifter **** that has four buttons on it that u can hook up anything to it with relays.i can find out what brand it is and try to get pics if anyone is interested.the shifter is usually used for neon lights and strobes but with a relay anything is possible so look into that.
Car: 1992 B4C 1LE
I know of customers that have inadvertantly hit the button at idle too many times and fragged head gaskets while waiting for the light to change to yellow going the other way thats why I recommend the throttle button. if you have to have a button under your finger, then run it in series with the throttle one so you can only manually activate it at WOT.
Car: 98 Camaro SS
Transmission: M6
Engine: 2005 LQ4
Axle/Gears: 3:54
ok the name of the shifter is called lol raceboy or racerboy.its for imports mostly and comes in a few different colors,my scanner took a **** so i cant post pics just yet but i will or ill try to find some online.in my opinion its rather ugly but its a unique idea.
Engine: 2005 LQ4
Axle/Gears: 3:54
well after a few mins of searching i found some pics and here u go.
Its called the Varad Racerboy Manaul shift **** they have diff models but im not sure what all the details are.
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I had my power switch set up through the fog light switch(no fog lights) in my GTA. I even had it set up to show a nice little light like the factory when it was "armed".
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
Switches
The upper red switch is the "arming", blue button is purge, back red is bottle heater and then the gauge...
Rick
Rick
Car: 00 TA, 91 Formula, 89 RS
I seem to remember a simple shift **** in the Jeg's catalog that had a simple red button on top of a black ****.
Car: 91 firebird now
Transmission: 5 speed
Engine: LS7
And shame on you for leaving your nitrous bottle open ALL the time. I feel sorry for you if your car gets treated like a rental. I like being able to tell anyone to try and find my nitrous switch and they come up clueless.
Car: 1992 B4C 1LE
my friend uses the "fasten seatbelt light" as his "armed" light in his 78 camaro
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd like to see the MGL # for that law in Mass..
1) Most N20 systems are DOT approved, and have CARB E0 numbers
2) N20 is non-flamable, and non-hazardous.
-- Joe
-- Joe
Street Lethal
Aug 13, 2015 08:28 PM
