Anybody have compressor map for Garrett T04b81 .6/1.0?
Old Dec 9, 2002 | 05:18 PM
92Z's Avatar
92Z
Just wondering how much horsepower this can support at a pressure ratio of 1.5-2.0 (7-15lbs. boost) on a 383 cu.in. making 450-500 N/A h.p. Thanks.
Old Dec 9, 2002 | 07:22 PM
89ProchargedROC's Avatar
that doesn't tell us anything....you need to measure the inducer of both the compressor and exhaust wheel
Old Dec 10, 2002 | 05:23 PM
CrazyHawaiian's Avatar
Car: too many ...
http://64.225.76.178/catalog/compmaps/fig6.html
Old Dec 10, 2002 | 07:11 PM
Well.............thats a start but he still needs top measure the wheel, hello 92z where r u?
Old Dec 10, 2002 | 08:13 PM
92Z's Avatar
92Z
It's a turbo I was considering buying. Garrett p/n 465366-18, s/n ke1019, AT04b81. Compressor side .60 M27, Turbine side 1.00. Don't know the wheel dia.'s. From what I have dug, it came off a Mercedes(diesel?). I think i'm going to pass, as I don't believe a single T04b from a diesel will support enough flow. Wouldn't a turbo for a diesel be efficient at low revs, since diesels don't rev high? I think on a small block it would be out of its efficiency range. That's why I was looking for a compressor map. Looks like I may need a t-76 or so. Any suggestions? Right now I am researching, but hoping to get started soon. Looking for around 600hp at anywhere between 7 -15 psi. Thanks for any help.
Old Dec 10, 2002 | 11:56 PM
that is going to depend on how free flowing your intake and heads are
the part numbers on turbos dont say much, you have to know the measurements
Old Dec 11, 2002 | 04:25 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
well what you should do is to get two of those turbos, and then that would be enough to feed your engine
Old Dec 11, 2002 | 04:36 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
A 66 may do the trick. If you wanna be definite and have plans for a higher stall(if auto) and better heads and fuel down the line an 88 would be a rocket. This all depends on the setup...
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
