Super Street NMCA 3rd Gen Camaro with BIG turbo on it
Old Dec 18, 2002 | 11:58 AM
Guido's Avatar
Car: 2000 Trans Am
http://www.proturbokits.com/
Scroll down to the photos of Todd Moyer's camaro.
Interesting if nothing else.
Old Dec 18, 2002 | 12:47 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
NMCA / Pro Fastest Street Car / The Clash of the Titans Super Street competitor Todd Moyer makes the switch from Big Block Nitrous to Small Block Turbo! Check out these early pictures from this awesome car.
Looks a lot like a big block to me Look at the valve configuration on the head...
either way thats one nasty combo. I thought your turbo was huge Guido
Old Dec 18, 2002 | 12:51 PM
Guido's Avatar
Car: 2000 Trans Am
Could be a version of the SB2 head. I know there are a couple different castings available out there and some of them use the spread port pattern like a big block does.
I was thinking the same thing as you though when I saw it.
Old Dec 18, 2002 | 01:07 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
The two center exhaust ports are not siamesed.
Anyone else notice all the welding work done on the heads aroud the valve spring pockets.
Old Dec 18, 2002 | 03:00 PM
bjm323's Avatar
Car: '91 Camaro RS
That is exactly where I was thinking I would put mine if I ever make the switch from nitrous to a turbo. What I want to know is, where the h#$$ the radiator is going. To run in the NMCA, I thought the radiator had to be in the stock location.
Old Dec 18, 2002 | 03:23 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I'm in love!
Old Dec 19, 2002 | 06:35 AM
Guido's Avatar
Car: 2000 Trans Am
I was wondering the same thing. LOL It doesnt even look like there is enough room for a SMALL radiator like a lot of the mustang guys use. *shrug*
And I wonder where they are putting the intercooler. In the dash?? looks like a stretch to get it there too. And that bumper cover cant be great for letting air into the turbo as close as it is sitting.
Old Dec 19, 2002 | 11:21 AM
StocRoc's Avatar
Man that thing is huge! My first thought was also about the radiator, I wonder where he will put it?
Old Dec 19, 2002 | 12:11 PM
MikeC.86Roc's Avatar
My thoughts exactly! Where the hell did he put the Rad?
Talk about talent though. That piping is beautiful. :hail:
Old Dec 19, 2002 | 12:15 PM
MdFormula350's Avatar
awesome looking!!
Old Dec 19, 2002 | 02:22 PM
Guido's Avatar
Car: 2000 Trans Am
Maybe he will be running a pair of radiators split on either side of the turbo itself. Ive seen it done before so it isnt out of the question.
Unorthodoxed? Yes
Doable? Yes
Desirable? I wouldnt do it. LOL
Id have mounted it closer to the drivers side, and then put a smaller, thicker radiator on the passenger side.
I wouldnt even do it like that period. Id have turned it 90 degrees from where it is and stuck it in front of the motor.
WHEN I convert to a big turbo like that (down the road) that is what I will do.
Old Dec 19, 2002 | 02:26 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
probably where the pass seat was...
Old Dec 19, 2002 | 02:40 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I don't think that is a big block, there is no way to run exhaust tubes like that with a stock strut suspension. I'm thinking SB2 heads or some other exotic head design. Those tubes look to be around 2", so it must be one strong motor. Any notes on the actual size in cubic inches? Or the time it ran?
Old Dec 19, 2002 | 03:16 PM
bjm323's Avatar
Car: '91 Camaro RS
I'm sure they will cut a hole in the facia for the turbo to breathe but that is illegal in the NMCA also. Dan Millen set the ET record in Columbus but they disallowed it because of the hole. As per NMCA:
Ram Air - Any aftermarket or fabricated ram-air unit is allowed, but it must not be visible from the exterior.
That is considered Ram Air. Anyway, it is cool as H@#$!!!
I would probably do the same as Guido stated. Offset it towards the drivers side as much as possible and use a narrow and thick radiator.
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I hope with the size of the heads and turbo it is the 468 cid sized small block one of my magazines this month had in the tech/write-in section. 'Dat would be shcweeeeet!
Old Dec 19, 2002 | 03:20 PM
Guido's Avatar
Car: 2000 Trans Am
Mr Moyer also races in the Clash of the Titans racing series which is a big race series of its own in Texas. LOL
Old Dec 19, 2002 | 05:49 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I've seen this car in person back when it was a nitrous car. runing high 7s.
About the heads, I saw a few SBC guys running Pontiac heads at Clash of the Titans, could it be them? Don't remember quite what they looked like (or could I see under the valve cover) just that the valve covers were huge like a BBC.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
