turbo or blower
Old Jan 7, 2003 | 06:07 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
turbo or blower
HEy guys i'm new to the blower and turbo thing. can someone please explain the diffrence? which one is more expensive and which one give more power? thanks guys
Old Jan 7, 2003 | 07:06 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: turbo or blower
A super charger (blower) runs off the crank of the car while a turbo uses your car's exhaust to spin a turbine to make boost. both make boost, superchargers are more parasitic than turbos, however in my opinion if you cant fabricate, superchargers are way cheaper and easier to do. Someone correct me if I am wrong, I am no expert on this stuff, but I am looking into getting a pro charger.
Seth
Old Jan 7, 2003 | 08:16 PM
MdFormula350's Avatar
http://www.howstuffworks.com/question122.htm
Old Jan 8, 2003 | 12:37 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
If you have no experience with either do some research... theres loads of information on the 'net (more than enough if you search the power adder board too). Basically a turbo has a turbine wheel which is spun by your exhaust gasses; which in turn spin an air compressor which is connected by a shaft, and compresses that air into your intake. A centrifical supercharger works the same way only in that the compressor is spun by a pulley connected to the engine's crankshaft. Research the idea and see what will be best for you (as simplicity, cost, etc.)
Old Jan 9, 2003 | 02:45 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
https://www.thirdgen.org/techbb2/sho...threadid=99267
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
