Turbine gaskets
Old Jan 12, 2003 | 08:34 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
Turbine gaskets
Are you using any sort of gasket between the headers/manifolds and the turbine input flange? Are you using any sort of gasket between the turbine output flange and the downpipe's flange?
Old Jan 12, 2003 | 08:46 PM
bhaas's Avatar
If your asking me then yes. I have a metal gasket inbetween the manifold and the turbo inlet and I used ultracopper for the downpipe gasket.
Brad...
Old Jan 13, 2003 | 07:08 AM
BOTLFED's Avatar
Is that a homemade gasket Bhass, or a purchased one? MORE INFO PLEASE! =)
Cheers!
Old Jan 13, 2003 | 08:37 AM
Guido's Avatar
Car: 2000 Trans Am
I am monty. I bought mine from Precision and they are a metal gasket. I bought them because I didnt have my flanges milled for flatness. Kept them visually flat but you know how that can turn out sometimes.
I added the gaskets for safe measure.
Old Jan 13, 2003 | 09:35 AM
Monty's Avatar
I didn't use any gaskets between the headers and turbine, or between the turbine and the downpipe initially. When I took everything back apart last week to have everything ceramic coated, I could see a few spots where a was getting a little exhaust leakage (tell-tale signs of carbon/soot on the flanges). No major leakage, but a little leakage nonetheless. All of my flanges are at least 3/8" thick stainless steel, so they should be pretty rigid and resistant to warping. I was thinking of buying some copper sheet, and making some gaskets from that. I bought a set of copper SCE collector gaskets for the header/turbine connection and they fit pretty well, but not perfectly. I'm using the PT52 turbo's, so they have the GN turbine flanges rather than the standard T04.
Thanks Guido, I just called Precision and ordered a pair of their copper gaskets for the header/turbine connection. Patrick at PTE said they normally don't use a gasket between the turbine and downpipe since a leakage there owuldn't effect performance, he said they do use Ultra-Copper silicone sometimes. I think I'll just leave it as is, as it is very minor leakage.
Old Jan 13, 2003 | 01:58 PM
bhaas's Avatar
Hey Bottlefed, here is the gaskets I used. Keeps us posted on your TT project.
Brad...
Old Jan 13, 2003 | 01:59 PM
BOTLFED's Avatar
Thanks man, but where did you get them????
Old Jan 13, 2003 | 04:13 PM
bhaas's Avatar
I got my gaskets and blockoff flange from this guy on e-Bay. He might have more or can get them. Here is his e-mail. bpmotoring@aol.com
Brad...
Old Jan 15, 2003 | 06:25 AM
BOTLFED's Avatar
Thanks Bhass, I just emailed him!
Cheers,
Old Jan 15, 2003 | 10:36 AM
Monty's Avatar
Thanks for the advice Guido, I got my turbine/collector gaskets from Precision yesterday, they appear to fit much better than teh SCE collector gaskets I bought. The Precision gaskets have a slightly smaller hole than the opening of the turbine inducer, appearantly due to the porting done to the turbine housing. I guess I'll get the die grinder and some cartridge rolls to gasket match it. But nonetheless, it's a better fit than what I had before.
sheachopper
Jul 31, 2019 11:27 AM
customblackbird
Oct 1, 2015 04:30 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
hdis2002
Sep 8, 2015 02:52 PM
