Fuel Managment for nitrous
Old Jan 18, 2003 | 11:08 AM
hydrota85's Avatar
I need to know if this would work. I am thinking of getting a electric fuel pump that will flow more then plenty for my engine and nitrous system together and then if i get a fuel pressure regulator with 2 out ports i could run one to the carb and one to the nitrous system. Any opinions would be helpful and if you have part # that would make this work please list them. Thanks
Old Jan 18, 2003 | 08:13 PM
BOTLFED's Avatar
A holley blue electric fuel pump comes with a 3 port FPR and works great.. It was enough to support my motor and a 150hp shot of N2O.
Cheers,
Old Jan 20, 2003 | 02:10 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I holley blue couldnt suppy my mild 355 and the 150 hp NOS shot. My car would literally run out of fuel in the bowls and sputtter to a backfiring stop on the track until I added another pump. Gary Rohe (NMCA EZ street champion) slammed "the little blue pump" because it can only supply at 6-7# pressure enough HP for about 300 RWHP max total. It makes a nice nitrous only supply pump in my opinion though.
Old Jan 20, 2003 | 02:16 PM
BOTLFED's Avatar
Heh, I must of got a good one or something then.. My blue could hold 9PSI at WOT with 150hp shot of nitrous, easy.... I don't consider my motor mild, but I also don't consider it to be wild either.. Should have been in the mid 11's on the N20 and ET Streets.
Either way, a better pump won't hurt, but a Holley blue will do what you want.
Cheers!
Old Jan 20, 2003 | 02:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
its certainly a possibility Ive seen some guys run a blue for years on the street and no problems and I have seen one sieze during the first few passes in its life at the track
Old Jan 20, 2003 | 02:22 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
What about limitations on stock lines? I have 460+ HP on the motor and I'm very weary about drawing my 150 shot's fuel from the rails. Any comments?
Old Jan 20, 2003 | 02:25 PM
BOTLFED's Avatar
Yea, I think their quality control leaves something to be desired.. I was installing a blue on my friends Mustang and the darn thing was putting out too much pressure for the non-return style regulator to handle and it was spitting fuel everywhere.. We thought it was the reg so I swaped in another one (we knew was good) and the same thing.. /sigh.. Put it back in the box and put a Crappy Tire special electric pump on it to get us by until we could exchange/return it.
OTOH, I've had mine on my car for about 5 years and not a single problem.. Now it's found its' way to my brothers turbo'd hurricane.
Cheers!
Old Jan 20, 2003 | 02:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
with a return style system and the 45 psi operating (or higher with afpr) with a decent fuel pump I think you are in good shape. with the return style system less just gets returned to the tank.
Old Jan 20, 2003 | 02:32 PM
BOTLFED's Avatar
JMatlock88: Wow, those are some pretty nice N/A HP numbers.. Can I ask what you have for a setup? Cam specs? etc etc...
I think what B4Ctom1 said about your fuel system is accurate.
Cheers!
Old Jan 20, 2003 | 02:55 PM
JMatlock88's Avatar
Car: 1991 Formula
I hope you all are right! Thanks for the compliment.
I was certainly preparing myself to run an auxillary inline pump on a separate pickup line from the tank.
Here is a general rundown of the driveline:
1969 350 4 bolt main .030 over
all name brand bearings, etc
all arp fasteners
forged crank and trw forged pistons
polished aftermarket ibeam rods
afr 195 68cc street CNC port
224 224 560 560 retro hydro roller custom grind cam
1.6 Crane race gold rockers
hardened pushrods
moroso pan
sfi 8" balancer
sfi flywheel
ministarter
stealth ram
58mm BBK
afpr
SVO 30s
msd pro billet distrib
crane hi-6s with timing retard **** for boost
accel supercoil
alum waterpump
alum 3 piece udrive pullies
hooker supercomp 1.75" longtubes
dual exh w/ 2 40 series flows
stage II 700r4 w/ torco 3100 lockup stall w/ antibalooning
150 NX shark nozzle w/ 10lb compucar bottle and solenoids
completely full interior w/ a/c and all options except ttops, rear defrost, foglamps.
brakes are stock
wheels are Ronal Firehawk 17s
aluminum 1le driveshaft
10bolt w/ 28 spline moser axles, 3.73s, cclip elim, alum stud girdle
spohn control arm lowering brackets
hotchkis control arms
ssm sfc's
tokico adjustable struts
all poly bushings
I'm getting ready to bolt up mufflex's 4" catback instead of the duals this weekend.
Old Jan 20, 2003 | 08:27 PM
hydrota85's Avatar
If i run a holley blue for my nitrous and a on the block pump that i have now would i run into any problems. I am thinking that it would work really good because i wouldn't have to worry about leaning out the nitrous because it would have more then enough fuel to run off of and my block pump has more then enough for the engine. I would also assume that the stock lines will be sufficent for this setup i am only going to run a 150 shot. I just want to make sure that i have all the parts ready so in the spring when i put them on i am ready to go to the track.
Old Jan 20, 2003 | 08:35 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that setup is just fine and very common.
Old Jan 21, 2003 | 06:07 AM
BOTLFED's Avatar
Nice setup JMatlock88, have you had a chance to run it at the track yet?
Cheers!
Old Jan 23, 2003 | 03:09 PM
JMatlock88's Avatar
Car: 1991 Formula
No, I just finished it (finished it? It's never finished hehe) in October. By that time, it was too cold. I really hope to get it out in early Spring to run in Tulsa or Noble. I will probably just get one or two runs before I get the boot. (no rollcage) :lala:
Old Jan 24, 2003 | 03:38 PM
NOSFEDGTA's Avatar
same kind of question here. I run a pro series holley black pump and was wondering if spraying a 150 hp would be safe with the stock lines and no return>?<
Drew
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
db057
Sep 4, 2015 07:57 AM
