Changing turbo compressor orientation
The turbine inlet and compressor outlet face the same direction. Is it possible to swivel the compressor a 1/4 turn to get it to make a right angle with the turbine inlet so I don't have to make crazy turbo piping?
Either one. I would bold the turbo down then undo the bolts on the compressor side. But if you oil ports aren't facing straight up and down then you'll have to loosen both sides and set it right.
Brad...
Brad...
Terrell351
Jun 13, 2021 01:13 PM
rh76camaro
Aug 15, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
