Really dumb downpipe question
Old Feb 23, 2003 | 09:42 PM
Iroc n roll's Avatar
Now, exactly how do I hook up a downpipe to this thing.....there are no bolt holes! Exhaust clamps? Weld a flange?
Old Feb 23, 2003 | 09:49 PM
another pic
Old Feb 23, 2003 | 11:59 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
looks like you need to use a V band clamp
Old Feb 24, 2003 | 07:04 AM
BOTLFED's Avatar
Yea, sleepybu is correct.. You need a pipe that has the same size ridge around it that is on the turbo.. Then you'll have to get a big V shaped clamp that will cover both ridges and hold them together when the clamp is tight...
Well, the clamp itself isn't V shaped, it's actually round, but the inside of the clamp has a V shaped groove..
Cheers,
Old Feb 24, 2003 | 08:21 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Ive seen those clamps on ford powerstrokes
Old Feb 24, 2003 | 10:02 AM
Is there a gasket or anything in betweem?...how does that seal? I guess not like it really matters all that much post turbo for performance.
Old Feb 24, 2003 | 12:01 PM
BOTLFED's Avatar
No gasket.. If both surfaces are true, then they won't leak.. The clamp itself may provide a bit of a seal when installed.
Cheers,
Old Feb 24, 2003 | 02:16 PM
WickedTwinTurbo's Avatar
If you go to your local truck parts store, they will be able to get you the ring that you need to weld on to the down pipe, the part that meet the exhaust housing ( its like a flare with flat lip to match the same size as the exhaust housing lip) Once you do that just pickup a V band clamp that is the same diameter put them together tighten.
Good luck
Prasad
Old Feb 26, 2003 | 02:41 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Detroit Diesel 6v92, Series 50, 6-92, Series 60, etc. Im an ex-diesel mechanic so Im kinda familiar with that stuff.
Old Feb 26, 2003 | 02:42 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Cheers,
Correctamundo... Check my previous post.
anesthes
42
Oct 24, 2015 07:30 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
