WHy am I only seeing 7 lbs of boost?
Old Apr 4, 2003 | 06:47 PM
89IROCZZ4's Avatar
I took my car to a shop today and they put a boost gauge on it. When getting on it for about 7-8 consecutive seconds, it only made a max boost of 7psi. Why is this? It has a 12 psi pulley, and is stock tpi. Could something be wrong with the supercharger? They also said the transmission was shifting soft and it felt like a stock transmission.
Old Apr 4, 2003 | 07:26 PM
bEtUr4dRustang's Avatar
Is this the car with the ZZ4 like your title? and do you have an intercooler?
Both of these things would bring boost down the way you are saying.
Old Apr 4, 2003 | 07:47 PM
89IROCZZ4's Avatar
yup thats me and yes, I have a 3 core intercooler. Should I put on my 15lb pulley to get more boost then?
Old Apr 4, 2003 | 08:51 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what kind of blower is this? roots? procharger? vortech?
Old Apr 5, 2003 | 12:00 AM
89IROCZZ4's Avatar
It is a procharger.
Old Apr 5, 2003 | 12:12 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it could be the "surge" or "bypass" or whatever they call it. other than that The most common, even more common than that valve, is a leak. a leak like that is hard to find because it actually doesnt sound like it leaks until boost is pretty high. try loostening wiggling and then retightening all the hose connections.
Old Apr 5, 2003 | 12:14 AM
89IROCZZ4's Avatar
They disconnected the bypass valve and it didn't seem to affect it at all. Could it possibly be that the supercharger is broken or something?
Old Apr 5, 2003 | 02:40 AM
89ProchargedROC's Avatar
is your motor COMPLETELY STOCK? if you motor isn't completely stock you wont see a complete 12psi
you also wont see a full 12psi until 5500rpm in 3rd gear
are you testing that way?
is there black dust around the blower?
^^if so, belt is slipping
Old Apr 5, 2003 | 09:12 AM
89IROCZZ4's Avatar
my motor is a completely stock zz4 if that counts. I also have completely stock tpi on it.
Old Apr 5, 2003 | 09:40 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Boost is created ~linearly with engine rpm. Let's rule out one of the most common problem, belt slippage. As your rpm's increase, you should see boost increase. At any given point, do you see boost increase stop while engine rpm's still increase? Or do you see 7-psig at your shift point?
Also, what pulley diameters do you have? To say, "I have 12 pound pulleys" doesn't mean anything. It's a purely relative term and every engine will create different amounts of boost with the same pullies. With pulley diameters, I can do some number crunching to tell you whether 7-psig is realistic with your ratio. Which ProCharger do you have?
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Dragonsys
Sep 25, 2015 03:51 PM
BBSDesigns
Sep 22, 2015 03:08 PM
