Super ram with nitrous plate problems
Old Apr 29, 2003 | 11:56 PM
kevin89formula's Avatar
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
89 firebird, I am running a superam with a nitrous plate after the throttle body. I am having problems fitting the air inlet elbow from the throtle body to the maf sensor. I have cut it down alot and it still wont fit correctly. any ideas on what i could do?. Could i use a trick flow lt1 air inlet elbow from summit, I thought I have seen a picture on this board with that set up, but maybe not. any suggestions?
Old Apr 30, 2003 | 12:22 PM
SmokinZ28's Avatar
I used a piece of 3" PVC from the MAF to an accordian piece from an IROC. Worked great
Old Apr 30, 2003 | 10:02 PM
Car: 89 formula 350
Transmission: t56
hey smokin, do ya think you could post a picture of that?
Old Apr 30, 2003 | 10:10 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Look at the pic in my sig for some suggestions. You can buy the 3" pipe at any decent hardware store, and the rubber inlet piece can be ordered from GM for like $7, just order the one for an 88 IROC.
Old Apr 30, 2003 | 10:12 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I'll have to post a newer pic, that one is old.
Old May 1, 2003 | 02:40 PM
SmokinZ28's Avatar
Here ya go
Old May 1, 2003 | 02:43 PM
SmokinZ28's Avatar
THis picture I'm using an NX fogger nozzle. When I used the stock TB I had a NOS plate behind it and it fit exactly the same cause the LPE TB is real close to the same thickness as a stock TB with the NOS plate
Azrael91966669
25
Jun 20, 2017 04:04 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
Sherpajames
Aug 7, 2015 06:56 PM
