All you Power Adder Carbed guys, what Fuel Pump you using?
Old May 2, 2003 | 10:41 AM
DFIance's Avatar
I have a Built 355 about 11:1 Compression, Sportman 2 Heads, Brodix Intake, Holley 830 Carb, 400 with a Brake and 200 shot.
I was looking into BG but is holley good too? What are you running? Prices?
Old May 2, 2003 | 11:19 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I use the Holley Blue pump. I hear the black is good also but don't get the red pump.
Old May 2, 2003 | 01:08 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Healthy 10:1 AFR headed 355 with a 200 NX Hitman plate..Holley black pro series..$150 jegs or summit.
Old May 2, 2003 | 06:57 PM
Mark W. Winning's Avatar
Barry Grant 400.
Old May 3, 2003 | 10:36 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Walbro in-tank TBI pump regulated down to 6 PSI with a return line and a voltage regulator to lower pressure during idle and cruise.
thing will last forever, and you dont even hear it.
Old May 3, 2003 | 11:37 PM
TwnTrboZ28's Avatar
Aeromotive A1000 - $290 new, cheaper on ebay
Custom voltage regulator - keeps pressure around 25 psi
Aeromotive fuel regulator (boost referenced)
Old May 5, 2003 | 10:40 AM
JucinGTA's Avatar
Dont mind me asking but did you guys run return lines? If so what line u using to run to and back?
Old May 5, 2003 | 10:58 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run a return line...braided line to (8AN) and from (6AN) tank.
Old May 5, 2003 | 11:17 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
i have a holley blue pump i got it off ebay for $95 with a regulator and guage jus one question to all of you guys where did you mount your blue pump at ?
Old May 5, 2003 | 11:53 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I use a Holly red pump. My car (1984 Z28 carb 355 150 hp NOS) has an elect. pump (3 psi) in the fuel tank to prevent vapor lock. This pump was installed by GM under warrenty. So I removed the drivers side rear seat and bolted the Holly pump on the body just above the rearend. At WOT a micro sw. mounted on the Q-Jet sec. actavates the Holly pump. I still use the stock chev mech. pump. The mech. fuel pump would not pull fuel through the Holly pump so I installed a Ford sol. (N.O.) that is used for switching tanks on trucks and is actavated by the same micro sw. This allowes fuel to bypass the Holly pump and just use the mech. pump and 3 psi elect. pump for normal around town driving. I still use the mech. pumps return line but I have a sol. on the return line that shuts off the return line at WOT. You guessed it, the same micro sw. shuts off the return line sol. That same micro sw. will also shut down the A/C compressor and the elect. rad. fan.
Auggie
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
