New coilovers installed, check THESE pics out! Also car hauler purchase w/in
1 Post
Car: 2000 Trans Am
Bought a 24' enclosed trailer and picked it up this weekend. We also installed wilwood's HD front brake kit, PA Racing coilover conversion and tubular a-arms. I LOVE the adjustable struts! Lowered the car along withthe 4th gen Z28 springs we added in the rear.
I know its not power adder related, but I talk to so many people here thought Id give a scoop on the ride. Hope to take it to the track Wednesday and start catching up with Tory.
1 Post
Car: 1992 B4C 1LE
DODGE? you drive a DODGE? OMG! j/k mee too
Car: 91 Maro & 97 Ram & 05 Roadstar
<Puts Flame Suit On>
Actually I don't think that Dadge trucks are too bad we had a 97 I think Ram. The only thing that I didn't like was there was no room in the back for passengers. As I frequently was a passenger.
Looks good Guido!
Just out of curiosity, what springs did you go with in the front? I ended up with a 200# spring, just wondering if you had the same. Nice trailer! that awning is a sweet option also.
BTW. good luck catching Tory! A few suspension adjustments, and a good track, he will be well into the 8's!
1 Post
Car: 1992 B4C 1LE
1 Post
Car: 2000 Trans Am
Originally posted by BlownBird
Looks good Guido!
Looks good Guido!
1 Post
Car: 1992 B4C 1LE
175? hmm I wonder what PA sent me with mine?
Car: 05' GTO
Engine: 6.0L
Transmission: A4
damn now it looks like a prostock car now by the way it looks. very sweet. and nice trailer. how much was it for the enclosed trailer?
You will be quite suprised how little cranking up on the coil nut will affect ride height. For every inch I adjust my coil overs it only changes the height about 1/4". It does, however, change the preload on the spring, and makes the front end come up at a faster rate.
I had thought along the same lines as you, but in actuality, if the spring is right for the car, you will only compress the spring with your adjustment, not adj ride height. A longer spring, or even a heavier spring is needed to adj. ride height.
I hope this makes sense how I explained it. Don't get me wrong, you can adj. ride height slightly, but you shouldn't be able to change it 1 for 1 (1" adjustment on the nut for 1" worth of lift).
Let Us know how you make out at the track.
1 Post
Car: 2000 Trans Am
Ideally, Id like to keep the height where it is. The lower the better. It scrapes the air dam even pulling it out of the trailer. Not badly but I dont want to do a wheelie and rip off my intercooler tubing either since it goes underneath the lower core support and through a hole cut in my air dam. LOL
I will likely leave it as it sits for the first time out to the track. WHich is shaping up to be Friday now.
Oh well, better late than never huh?
Car: '91 Camaro RS
Looks good Guido. I bought a set of used AJE coilover struts. The guy was running a small block. He started off with a set of 175# springs but had to step it up to 200# to try a settle down the big wheelstands. I'm sure his car was lighter in the frontend being that it was a nitrous SBC. Didn't have the extra weight of an intercooler and the turbo. What size tire do you have on the front? I like the way it fills the fenderwell nicely.
1 Post
Car: 2000 Trans Am
Replacing my master cylinder tonight and our plan is to have it out Friday evening. I have my eyes set on a 9 second pass. I want to get kicked off for no license. LOL
1 Post
Car: 1992 B4C 1LE
Originally posted by True Power
Excellent, be sure to get video
1 Post
Car: 1992 B4C 1LE
hey guido can you tell me anything about your back space rim width and tire choice?
1 Post
Car: 2000 Trans Am
jefft emailed me about that too.
15 x 10 Weld Pro Stars with 5.5" backspace. The tires are 27 x 11.5 15 Hoosier QTP.
I had to cut off the bump stops and hammer in the front of the inner wheel well to get them to fit. I would like to change to a 15 x 10 rim with 6" backspace to get it further under the car but I fear that I will have to mini tub if I do that and I want to do some racing so going to see how these tires work out for the time being. I have a set of 28 x 10.5 MT ET Drags but want to save them for when I put the new rims on.
1 Post
Car: 2000 Trans Am
Yes we are. A friend of mine has a digital camcorder but we havent quite figured out how to get the video off of the camera and onto a computer yet. LOL We will figure it out soon.
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
you guys would be suprised what happens when you add 50/75/100 lbs to the front of a 9 second car.
How are the Coil overs on the street? I have the PA X Member sitting here and am about to order the A-Arms and Coil overs. My car will be a street car more than a track car and wondered how they handle on the street?
