pcv system w/ procharger????
Old May 15, 2003 | 08:36 AM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
Could I just route the passenger side to air filter(just poke a hole in the top side of the K&N) and keep the pcv and hose stock on the drivers side? Oil is leaking and I dont like it at all so I would like to get my pcv working again to help stop the leaks (or at least help)
Also, if I run the lines as I described do I have to worry about sucking oil thru the charger and will there be enuf vacuum?
Old May 15, 2003 | 11:41 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I removed my PCV valve completly ( cut the bottom and removed the spring).... Just put a hose and vent it into the atm. on both sides.
sleprock
Sep 24, 2015 04:33 PM
vortech305
Apr 17, 2001 08:43 AM
vortech305
Mar 26, 2001 12:42 PM
vortech305
Feb 28, 2001 11:44 AM
Trevor 91 Formula
Jul 27, 2000 11:40 PM
