volvo turbo?
Old Jun 1, 2003 | 11:03 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
volvo turbo?
hey, i found a turbo and intercooler set for sale from a 81-85 volvo. does anyone have any idea how big this turbo is and if it would be worth buying?
i have a 87 camaro 2.8-3.4 swap done and was SERIOUSLY thinking about a turbo swap. i know the piping is a major setback but i work at a machine shop so that would be no problem. one thing is, i dont know what to do with the electronics. i have no idea whats involved with that so while you're at it, can anyone help me out in that department too?
Old Jun 1, 2003 | 01:45 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
You'll need a fuel pump(walbro 307 at least). Injectors(28lber's at least/stock GN). A boost sensing fuel pressure regulator. You'll need a map sensor(for your boost gauge). You'll nee a chip burnt for you to bring the combo semi close then tune using timing and fuel pressure.
Gonna be a hell of an ordeal since the 3.4 isn't a performance engine(crank and rods may not hold) and nobody has done it before. The cost and time involved unless you are stuck on a turbo. I'd look into an eaton s/c. do a search on the power adder board about the eatons(pontiac GTP/Bonneville/lightning,svt cobra, etc.) There are guys that have done it on 8's I'm sure it can be done on the six.
Along with the eaton you'll need the regulator, fuel pump and injectors still.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
