fuel cell for NOS
Old Jun 15, 2003 | 01:51 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
fuel cell for NOS
i am now running a 3 gallon fuel cell (from summit) for my NOS system that i have 110 octane union 76 race fuel in . my question is , will the fuel go bad after a couple of weeks ? the tank is mounted in the left front corner of the engine compartment with a holley blue pump. the vent on the top of the cell has a hose that just runs back a little ways and is open
any thoughts or opions will be welcomed
mike
Old Jun 15, 2003 | 01:29 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it takes race fuel a while to totally spoil, but sometimes from the time the fuel is poured to the time it is used, the specific gravity can change from evaporation of its lighter parts through the vent and it can oxidize and "sour" a tiny bit. My fav way to tell when its going bad is from the smell, but then again sniffing leaded fuel kills brain cells so what do I know...
Old Jun 15, 2003 | 01:30 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
a cell like this?
Old Jun 15, 2003 | 02:31 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
yes , but a little bigger. is that a return line in the bottom? what is on the top fitting , cap or vent? i didn't think i coult fit the 1 gallon cell up front because it is 12" tall.
Old Jun 15, 2003 | 04:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
pinhole sized vent
Old Jun 16, 2003 | 11:55 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Got any pics of it installed?
Old Jun 16, 2003 | 12:28 PM
NOSFEDGTA's Avatar
It will fir automec. I will send a picture of mine installed. I would just post it here but I cant cause I am on provbabtion "been like a year and dont know why" but anyway shoot me your e-mail and I will send a pic of my set up. I run a vortec t-rex efi pump. I have my return on the top. I use a mallory regulator with a return.
Drew
Old Jun 16, 2003 | 12:41 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
robert@keany.freeserve.co.uk
Send it to me and I'll post it.
thanks
Rob
Old Jun 18, 2003 | 01:40 PM
NOSFEDGTA's Avatar
cool, I have sent them to you. Thanx for offering to post them.
Drew
Old Jun 19, 2003 | 05:09 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Please post the pictures. I plan on doing the same thing, but there's almost no one runing something that serious.
Old Jun 19, 2003 | 05:34 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Please email me the pictures... I can host them if need be..
ben@fuelslut.com
Much thanks.
Old Jun 20, 2003 | 09:56 AM
NOSFEDGTA's Avatar
ok I will re-email the pics. when I get home tonight to someone that can post them..
Drew
Old Jun 21, 2003 | 11:56 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have a one gallon Jaz "Nitrous Enrichment" fuel cell like the one pictured above. I haven't mounted it yet but I was thinking in the front where the battery or charcoal canister was. I don't like the idea of cutting a hole there though....
I'd love to see the picture of how you mounted it also.
Old Jun 21, 2003 | 11:08 PM
onebadwagon's Avatar
just for the love of all that is holy, make sure when out racing, DO NOT LET IT RUN DRY.
adam
Old Jun 22, 2003 | 09:51 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
hmm i was thinking of mounting mine in the trunk space, below the sub box. easy to run the lines out from there and to a little holley blue. think it will work?
Old Jun 22, 2003 | 11:02 PM
Car: '89 IROC-Z
It wouldnt be safe nor NHRA legal to run it in the hatch. You need a rear firewall to put a cell in the car.
Old Jun 24, 2003 | 12:01 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
hmm but its legal to put it in the engine bay? sounds a little strange. if im drag racing im going forward not backwards... (hopefully)
Old Jun 24, 2003 | 01:04 AM
Car: '89 IROC-Z
NHRA rules say (If I remember correctly) the cell cannot be mounted outside the "confines" of the frame or a frame made of 1" mild steel must be made for it. If you get into a bad accident and the fuel cell catches fire it'll be outside of the car and not inside with you. So ANY place but inside the car is better/safer. I've seen a few thirdgens have firewalls built into the hatch of the car but I don't think thats very fun to do.
NOSFEDGTA can you send me the picture? chris255@earthlink.net nobody seems to be posting it for you so I will. I'm real interested in seeing how you placed it.
Old Jun 24, 2003 | 09:01 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Yea he's not the only one. Where's the pic?
Old Jun 24, 2003 | 01:25 PM
NOSFEDGTA's Avatar
Ok I have sent pics to 2 more people. I hope all goes well..
Drew
Old Jun 24, 2003 | 03:47 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
http://swallowed.splooge.org/fuel_cell/Mvc-027s.jpg
http://swallowed.splooge.org/fuel_cell/Mvc-028s.jpg
http://swallowed.splooge.org/fuel_cell/Mvc-029s.jpg
There you go.
Old Jun 24, 2003 | 06:49 PM
Car: '89 IROC-Z
I was thinking of mounting my cell like that but I was scared to have the supply line facing the front of the car ...although there is foam inside the cell. I was thinking of cutting a hole in that area so it could drop down and look nicer but I shed a tear every time I cut my car up.
Old Jul 1, 2003 | 01:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Sorry I never posted the pics. I ended up getting a last minute flight and decided to go on holiday for 5 weeks or so and don't have access to that e-mail address.
Pics look good though.
Robert
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
