This could help with turbo header buildups
Old Jul 11, 2003 | 01:28 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I am not sure if anyoen has seen this but http://www.burnsstainless.com has pre built collectors with turbo flanges for sale on their webisite, I think this could make a header build up alot easier. I just wanted to share incase there is someone who hasent see it.
I also found these pics, looks liek a good siple idea:
Old Jul 13, 2003 | 09:15 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah thats a motor on ebay the headers are for sale I have seen two turbo setups using variants and modified versions of these headers. I was trying to figur out what they were because they look so much like block huggers but have some serious differences (the locations of the primaries in the collector. Then it struck me. they are vette stock or vette aftermarket. the ones I saw were like them were from/for LT1 vettes but other may be too.
Old Jul 13, 2003 | 02:56 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
so you think they are just inverted headers with a turbo flanged like welded onto the colectors?
Old Jul 13, 2003 | 03:00 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
they may also have been pulled in closer to the block but essentially yes.
Old Jul 13, 2003 | 03:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
but wouldnt that location hit the edges of the fenders?
Old Jul 13, 2003 | 03:57 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yould not recommend using those headers in our cars unless you were going to modify them and use them like this:
Attached Thumbnails This could help with turbo header buildups-turbosmitty3.jpg
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
and even then the guy that built that modified his inner fender well and maybe more to get it into his thirdgen.
Old Jul 13, 2003 | 09:28 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
That a pretty good idea in that pic B4Ctom1 attached. That would probably one of the cheapest ways to do it jsut as long as it clears all the belft driven accessories. I am not planning on putting a turbo on my camaro I want to do it too my C-10 project, this is all research for me, thanks for the input soo far.
Can headers be bolted on upside down? Are the angles the same? or would a machine/exhasut place have to modify them some how?
Old Jul 13, 2003 | 10:11 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
good luck, I have considered doing the same to my very very ugly old junker trash truck just because it has a solid drivetrain and frame. I figure to L98 swap it first. Its hard to find any exhaust shop willing to modify a header, as far as turning them upside down it all depends on which header you are going to use nobody knows until they try. I might even try it with stock manifolds then go to headers later. just to make it look slower from a racing point of view.
Old Jul 13, 2003 | 10:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the exhaust ports ARE a mirror image, so they will bolt up... as for if the idea will work.....i donno. ive thought of it before though....
Old Jul 14, 2003 | 12:10 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I really want to try the inverted thing now!! If I can find a resonable priced set of used block huggers I may try it. With the truck I dotn have to worry about the low hood line or the shock towers being 6 inches away from the block, so I have some room to experiment. Well now my search is on. Im also looking for another t3 from a 87-88 thunderbird if anyone knows of one around. Ohh man Im adding this all up in my head soo much for budget twin turbo project.
Old Jul 14, 2003 | 03:10 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
ebay is full of new and used block huggers and turbos
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
