Shade Tree Turbo Install
Old Jul 18, 2003 | 10:38 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
OK I have my ElCamino with the Turbocharged 350. But the issue is that I have is that at 5000 RPM's I have about 20 psi of boost (way too much for a stock SBC). So I need to reduce boost. My question is can I get a BOV that will be able to blow off the excess boost down to 8 psi?
The turbo I have is off a Diesel Semi (Junkyard) and has no wastegate. So will a BOV suffice or do I need an aftermarket wastegate?
Thanks, Garrett
Old Jul 18, 2003 | 11:05 PM
True Power's Avatar
A wastegate will actually keep the boost down. A BOV just lets the pressurized air in the intake tube vent out whe u shift or left off the throttle
Old Jul 19, 2003 | 12:09 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Going to need a waste gate.
Do you have any specs on your turbo? Make and model semi would be cool.
Old Jul 19, 2003 | 06:50 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Shade Tree Turbo Install
Over cooked by that much can be difficult for a BOV, or wastegate to control.
You might think of adding a restriction pre or post turbo in the exhaust, to reduce it's ability to spool the turbo. Remembering it'll have to deal with ALOT of heat.
Old Jul 19, 2003 | 07:36 AM
jon_volk's Avatar
tial 40mm external wastegate should take care of that. not cheap though.
Old Jul 19, 2003 | 09:36 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I wanna know what turbo he found to make 20# with!
Old Jul 19, 2003 | 03:57 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
What kind of deisel semi did you get that turbo off of? I have access to some big deisel turbos but I did'nt know how they would work on Gas engines. The turbos I'm talking about are massive. They are on 500 hp CAT powered Freigtliners.
Old Jul 20, 2003 | 08:20 AM
Car: 1991 Formula
Well to tell you the truth the 20#'s is an estimate. (But at about 4000 RPM's the bottom end is about ready to come through the oil pan).
The turbo is a Garrett, off an international truck. Were can I look on the turbo to find out specifics?
I'm putting a new boost gauge on the car today and then I'll let you know exactly what kind of boost we are talking about.
Thanks, Garrett
Old Jul 20, 2003 | 11:05 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
even pictures would be helpful, maybe next to a ruler
Old Jul 25, 2003 | 08:44 PM
Car: 1991 Formula
Well the boost gauge that I bought at a swap meet was junk so no boost numbers. But I can tell you that I'm not a turbo expert, but the turbo will blow the bonnet of the carb. and you can't hold your hand over the turbo when the car is idling.
Here's a pic of the turbo. Any input is greatly appreciated.
Thanks, Garrett
US 1/4 in pic for scale
Old Jul 28, 2003 | 03:27 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
hahaha definitly a deisel turbo, my dads cummins will run over 30#s under heavy load and run at 16-20 unloaded, its a holset 12cm2 housing in his truck tho. did u get that off a power stroke?
Old Jul 28, 2003 | 07:38 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it has no waste gate in the above picture I would say thats what it needs. here is a picture of the deltagate external wastegate installed and a beautiful example of a awsome way to employit done by smitty and then ruined with my red paint. With the red paint though you can see how the wastergate when actuated via boost/vacuum line can bypass exhaust gasses around the turbo to reduce the boost. Deltagates are adjustable. I saw a used deltagate sell for $150 on ebay a day ago and it came with a spring for 4-6 pounds of boost adjustment and one for 8 to 12 pounds of boost adjustment (both estimated). I hope this is helpful.
Old Aug 4, 2003 | 09:00 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Depending on how low you want to set your boost, you will need a bigger wastegate than a delta. You might want to invent in a racegate. They also pop up on ebay, but not as often. I would suggest going with the racegate anyway. You will probably never out grow that thing.
Old Aug 5, 2003 | 01:52 AM
83 Crossfire TA's Avatar
First, boost has little to do with the actual turbo creating it, all it is is a measurement of the restriction to the flow that the turbo can produce by the engine. If you make the engine more restrictive boost goes up.
Second, that’s definitely not a powerstroke. They have specific center section flanges that incorporate the oil inlet and outlet on one flange, where that one has a separate inlet and outlet
Old Aug 7, 2003 | 06:33 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have looked at that thing over and over and I think its a regular large A/R T4 look at the exhaust plange and twin inlets.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
lee01
Apr 9, 2016 01:56 PM
fasteddi
Sep 2, 2015 10:29 AM
crazynights
Aug 21, 2015 06:53 AM
