5/16 fuel line enough for 150 shot?
Old Jul 23, 2003 | 10:01 PM
definitive1's Avatar
basically, exactly what the subject says. I want to use my return line as a fuel supply line for a max. 150 shot. Im planning on using a holley blue pump and regulator.
Old Jul 24, 2003 | 04:22 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I think the 5/16" line can support fuel for a stand alone 150, just make sure its getting its own pickup line as well.
Old Jul 24, 2003 | 11:19 AM
yeah the line is totally separate from the main fuel line in the tank, so i should be alright, Thanks
Anyone else???
Old Jul 24, 2003 | 08:38 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I think its a bad idea because you still should have a return line for the nitrous system. A buddy of mine used to spray his mustang without a return line on his nitrous system and he had to hook the solenoids up seperatetly due to fuel lag.
So in other words ....He'd leave the line with just the fuel solenoid opened and the second the motor started to bog he'd turn on the nitrous solenoid. If he activated them both at the same time he'd lean out and detonate (don't ask how the motor survived the first few spray runs). Anyway, he added a return line (like NOS's diagrams say to) and no longer has this issue.
Old Jul 24, 2003 | 08:57 PM
yeah i see what your saying.... I think I might just go with a small fuel cell... I really dont want to tap into my main fuel line, so I think thats the best bet, besides running another line to the tank, which I def dont want to do.
Old Jul 26, 2003 | 02:47 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
small cell
Attached Thumbnails 5/16 fuel line enough for 150 shot?-fuelcell_finished-above.jpg
Old Jul 27, 2003 | 03:50 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Originally posted by B4Ctom1
small cell
Is that track legal?
Old Jul 27, 2003 | 11:50 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
actually it wasnt in the picture, not until I added a ground wire to one of the studs on the filler hole ring, but afterwards yes.
Old Jul 28, 2003 | 12:25 AM
jester111's Avatar
hi
its perfectly fine for feeding the nitrous fuel supply only.
i know of a someone that was using it to feed a 9.30 et car.
just my input
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
fasteddi
Sep 2, 2015 10:29 AM
AkDrifted
Aug 17, 2015 07:45 PM
