fuel pump dedication, nessecary?
Old Aug 18, 2003 | 01:16 PM
MouseCamaro305's Avatar
i'm using a nitrous kit (150 HP pills)on my zz4 350 (hypers) i'm using edelbrock's supposed high flow mechanical street pump. before i fire the nitrous i want to make sure i have adequate fuel flow, i'm waiting on a pressure guage, and i was wondering this: should i plumb a high flow electric fuel pump to the carb and run the mechanical pump to the sollenoids? it seems like it would make sense to send more fuel to the carb which more than likely uses more fuel than the enrichment solenoid.
Old Aug 18, 2003 | 07:12 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I am a believer in the dedicated setup, I ran the motor out of gas with one of those holley blue pumps and ever since then I been a believer in the dedicated setup...
Old Aug 18, 2003 | 10:03 PM
tom, thanks for the reply.
do you think the setup i suggested in the above post, about using a dedicated mechanical pump to the enrichment sollenoid and using the electric pump to run the carb is a wise idea? or would it be better to run two electric pumps and delete the mechanical pump?
thanks again
Old Aug 18, 2003 | 11:53 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I recommend running the carb with the nice mechanical pump and the enrichment off a electric pump that can be turned on and off with the nitrous arming switch.
Old Aug 19, 2003 | 11:01 PM
tom, thank you very much for the reply, however i'm a bit confused on how the plumbing would go, would it be wise to run the electric pump before the mechanical on the same fuel line? or would that be parasitic to the mechanical pump?
thanks again
Old Aug 20, 2003 | 01:40 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
no I think I may have mis-communicated this.
what I mean is for two independant fuel systems including a added pickup, one with the electric pump for the nitrous and one with the mechanical for the carburator...
Old Aug 20, 2003 | 01:07 PM
now i understand, would i be able to plumb an additional pickup into the stock fuel tank, or would it be better to run a small fuel cell perhaps with a higher octane fuel for the enrichment solenoid?
thanks again
Old Aug 21, 2003 | 12:04 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
either works well
Old Aug 21, 2003 | 07:34 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Just make sure you run a regulator with a return line. If you dont it will lean out really bad when you hit the button. Nitrous express actually does not recommend running a dedicated fuel system, but I think the only reason they say that in their manual is because they want to limit the number of things people can screw up. I plan on running a dedicated fuel system with a Jaz nitrous fuel cell. That way I can put race gas in the fuel cell and have instant octane boost when i need it .
Old Aug 22, 2003 | 12:27 AM
thank you guys very much for the responses- theyre greatly appreciated
Old Aug 22, 2003 | 02:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I really love NX products but they say some screwy stuff sometimes they say in the destructions that retarding the timing on nitrous isnt really necessary, yeah right. I think you are right on with that "limiting the number of things a person can screw up..."
Old Aug 22, 2003 | 02:32 PM
lol no kidding, i plan on taking some timing out as well .
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
