Custom Fuel Cell
Old Sep 4, 2003 | 06:47 PM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Custom Fuel Cell
Ok my last thread was Hi jacked and then closed so i will restate my original question with more detail
I want to make a custom fuel cell to fit in a tight spot. Has anyone ever done this? or is it even worth it?
I want it resonably safe
Old Sep 11, 2003 | 11:33 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
You can find a wide variety of fuel cells to fit nearly any space.
in my opinion, making a fuel cell, unless you know exactly what you're doing (you're in the industry maybe) could be dangerous, and worse yet, illegal in organized racing
slick
Old Sep 13, 2003 | 07:41 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Fuel cells can be anything from the blow molded plastic RJS cells for $50 from Summit to cells that are well over $1k with fabricated aluminum tanks, multi-layer liners, and foam. It's not rocket science. If you were to make your own from aluminum, check with NHRA/SCCA rule books on specs, and follow them for your own safety. If you can weld well, you can make a decent cell. Drag racing cells are pretty simple, since there doesn't need to be baffling to keep fuel flowing to the pump in the corners. What's your plan?
Old Sep 13, 2003 | 08:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by askulte
What's your plan?
Don't ask.
Old Sep 13, 2003 | 08:34 PM
D M N's Avatar
Engine: 3.4 DOHC
Originally posted by Apeiron
Don't ask.
What do you mean by that?
I want to make a fuel cell to fit to the trunk but also i want to make a opening for the fuel to enter from the taillight. I want to have a flip out tailight with a filler head
Old Sep 13, 2003 | 11:05 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
What's wrong with the stock fuel tank? Convert the feed line to use a -AN fitting in the engine bay, and get a length of hose that'd you'd connect when you want to pump out the fuel. I would wire a switch to manually turn on the fuel pump, and simply pump whatever fuel is in there to 5 gallon fuel jugs.
A.
Old Sep 14, 2003 | 09:59 AM
D M N's Avatar
Engine: 3.4 DOHC
I want to SC my car and ad race fuel (wood alcohol)
Old Sep 25, 2003 | 09:26 PM
dennis6's Avatar
Car: 1991 Camaro RS
Summit sells a cell made for street rods that I think will fit. Here is the link:
http://store.summitracing.com/partde...t=RCI%2D2161AD
Thinking about doing this myself.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
