PCV question w/ total seal rings......
Old Sep 24, 2003 | 02:00 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The machine shop told me that I might have a problem w/ excessive crankcase pressure using these rings. He said to make sure that the PCV system was working properly. Would there be a downside to just sticking a breather in the valve cover? What is the correct way to do this.
I don't want my dipstick blowing out of the tube.
Old Sep 25, 2003 | 02:05 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ttt
Old Sep 25, 2003 | 03:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Wouldn't crankcase pressure only be a problem if the rings weren't sealing?
Old Sep 25, 2003 | 06:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
its the opposite, total seals allow less blowby
Old Sep 28, 2003 | 03:48 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
One more thing, I got new valve covers and they didn't have any holes in them. Well I drilled one hole for the PCV one way check valve in the drivers side cover. Do I need one on the other side? I didn't think so, but I wanted to make sure.
Old Sep 28, 2003 | 04:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The purpose of the PCV is Positive Crankcase Ventilation.
It's to ensure that there is some air movement thru the cranckcase to min the build of sulfuric acid fumes.
One valve cover has the valve and the other the filter.
Problems arise when the blowby is great enough that there is no fresh air dwarn thru the system. Or oil fumes are carried thru the PCV system into that intake manifold.
Not to be confused with crankcase evacuation systems, or negative crankcase pressure systems.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
sreZ28
Oct 22, 2015 08:21 AM
jaridjohn
Oct 5, 2015 07:01 AM
david068513
Sep 18, 2015 10:36 AM
