good heads for a turbo
Old Sep 25, 2003 | 10:10 PM
matts90firebird's Avatar
hey guys my head gasket is on its way out
so i figured since i have set of stock heads i might as well pick up some reasonable heads during this repair
i bought a turbo setup
all i need is the turbo for my turbo system but i wont be putting it on till next summer (if that soon)
im wondering what are some good heads that i could upgrade later to use with my turbo
i would like to keep it under $600 for the set (ill most likly be picking them up this weekend at english town swap meet
please get back to me for im goin to englishtown on saterday
thanks guys
Old Sep 26, 2003 | 02:33 AM
Dan W's Avatar
About the only set of heads you'll find for less than $600 are the vortecs.
A set of good heads for a mild turbo setup will be will be much the same as for a street setup. Keep in mind that you want to keep your compression down so you dont detonate under boost.
The AFR heads offer a thicker deck surface that can make a difference if you start running mad amounts of boost.
Old Sep 26, 2003 | 07:41 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Yeah I can think of plenty of "good heads" but nothing that comes to mind that are under 600...Unless you find a deal on a good used set..
Old Sep 26, 2003 | 11:19 AM
well what about if i boost my limit up to 1000
that is stretching it but i should be able to make it
what do u guys think
and what is a good set of gaskets i dont want to have this problem again with my head gasket
ive read alot about the sportsman IIs what do u guys think about their setup
Old Sep 27, 2003 | 04:14 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Nothing wrong with a set of ported and polished L98 heads. I just bought a pair with 1.6 roller rockers and larger valves for $250.. It was family that sold it to me, there are always deals out there if you can find em.
Phyte
Old Sep 28, 2003 | 02:50 AM
Dan W's Avatar
Sure, ported heads will work but to find a cheap set that are done properly are rare because it takes lots of hours to port heads. If you have plenty of time and want to go really low buck you can do some porting yourself but w/o a flow bench you should probably limit yourself to bowl work.
Old Sep 28, 2003 | 09:47 AM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
My cousin bought a full L98 350 TPI out of a junk yard camaro for $300. When he cracked the engine open he got quite a surprise Fully ported heads(the ones I bought), ported TPI, comp cam, and dish pistons. He sold the heads to me for $250 and the TPI setup to my Dad for $300 including computer, harness the whole bit. It was a great find.
Phyte
Old Sep 28, 2003 | 07:03 PM
hey guys i got back from the swap meet last night
i picked up a set of trick flow 195 cc heads 23 degree 2.02 intake and 1.60 exhaust and they have a 64cc combustion chamber
im goin to mill out the combustion chamber to 70 or 72 something like that because of the turbo setup i need low compression
has anyone used these heads on this board or does anyone know some one who has used these heads
im wondering what kind of power im goin to get out of the engine before i turbo it
i have 350, a performer intake, 750 cfm holly carb, and a stock bottom end (im thinking about buying a short block forged)
tell me what u guys think
thanks guys
Old Sep 28, 2003 | 07:22 PM
89ProchargedROC's Avatar
any heads will work well with forced induction.....its just that if they dont flow too well you are going to have to run a lot of boost to make the power you want
if you run cast iron i wouldn't worry much about which you choose
if you run aluminum you have to worry about the thickness of the deck and if you buy them used you have to make sure they haven't been milled too much or they wont seal well
Old Sep 29, 2003 | 02:26 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
I would not bother with changing it unless your going to run seriously high boost or the CR is over 10.0 to 1 .... Plenty of people out there running 9.5 to 1 on higher boost apps with no problems..
As long as your setup is not like 10.5 to 1 you will be ok PROVIDED YOUR CAR IS TUNED PROPERLY AND YOU HAVE ENOUGH INJECTOR TO HANDLE THE SETUP...
Or you can run a thicker head gasket and make up some of the loss** or a Dished piston...
Old Sep 29, 2003 | 11:22 PM
i know what u mean but just to let u know im goin with a holly 750 cfm
so that hole injector idea is a little hard to do
but i know what you mean.
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
