compcams nitrous HP cam?
Old Oct 5, 2003 | 07:41 PM
miker61588's Avatar
compcams hp268
would this cam give me a bit more power with the spray? how would it compare to the xe268?
Old Oct 6, 2003 | 07:12 PM
Damon's Avatar
It;s similar to the stadard XE cam but with a slightly wider lobe separation angle (113 vs. 110) and even more exhaust duration to make sure the large amount of exhaust gas that nitrous creates can get back out of the cylinder.
For a street-driven nitroused motor you have to trade off between good N/A performance driving around town and maximum effort on the bottle. I have found it's a better trade-off to just up the nitrous jets a little more and build the motor for good off-bottle performance. Makes daily driving more livable.
Old Oct 7, 2003 | 11:26 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
we never blew head gaskets until we installed the nitrous cam but we did get more brake vacuum.
Old Oct 7, 2003 | 02:56 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
friend of mine has a monte carlo running 10.70's with the NitrousHP 274 cam and a 175shot ...and on a dyno while spraying the 175 shot he gained like 230HP so I'd say those cams work real well
Old Oct 7, 2003 | 05:46 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Damn, not bad at all. Whats your friend's setup if you dont mind sharing.
Old Oct 8, 2003 | 08:21 PM
Car: '89 IROC-Z
its a 355 with heavily ported Iron Eagles (180cc I think), cam is advanced 7 degrees, 4.10 rear with 28" tall tires, 8" converter ...thats about all I know.
Old Oct 9, 2003 | 10:08 AM
Cam is advanced with nitrous? I thought that was a nono? Just ignition timing?
Old Oct 11, 2003 | 08:53 PM
Car: '89 IROC-Z
He gained like 3 or 4 tenths I think by advancing it.
Old Oct 12, 2003 | 11:00 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I remember you can help out a car with too litlle or too much compression bay advancing or retarding the cam but which is which?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Strick1
Sep 4, 2015 07:11 AM
