Toro leafblower supercharger???
Old Mar 14, 2004 | 04:18 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I was browsing cardomin.com and came across a kid with a TBI third gen with an electric leaf blower plumbed into his ducting plugged into a power converter. He claims a .5 sec. reduction in E.T... I checked on leaf blowers, and some can blow 200mph. Its only a $150 investment with the power converter, so im seriously thinking about it. I have TPI so i will have to come up with an air filter before the blower. I want my plumbing to be more sealed than his (pic enclosed). Will this work???? I will only hook it up for the track and turn it on at wide open throttle. Im i crazy???
Im all about budget racing, i have some cheap mods i learned from this site and other sources. check my webpage http://www.cardomain.com/id/2quikk4u
tell me what you think about this idea, it is amusing if anything!
Old Mar 14, 2004 | 05:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Old Mar 14, 2004 | 06:04 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i don't see how much of an improvement it would show.
however, if you wanna try it. go for it.
Old Mar 14, 2004 | 06:10 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i gotta admin it kinda sound liek it'd be cool, but i dont think it would be that great of a mod. Superchargers add a tone thats just, dammit i forgot the word, but its very special. Turbos are cool too but are expensive.
Shane
Old Mar 14, 2004 | 06:44 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Buy it and post some before and after dyno numbers.
Old Mar 14, 2004 | 07:12 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
So im the guinny pig for this experiment huh????
I'll try it once it gets a bit warmer here in WI. I can always use the blower and converter if it don't work. I will document everything with my G-Tech.........
I'll keep it updated on my site.
http://members.cardomain.com/2quikk4u
Old Mar 14, 2004 | 08:48 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Old Mar 14, 2004 | 09:07 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Shane
like a whining sound?
you should see some of the videos of the 8 second turbo cars. they hiss something fierce.
Old Mar 14, 2004 | 10:28 PM
EvilCartman's Avatar
Car: '82 Z28
Old Mar 15, 2004 | 06:36 PM
cbmotorsports's Avatar
Car: 1988 GTA
Engine: 5.7
Some people have too much time on thier hands. Just spend the money and make some real boost. QUIT RIGGING THINGS.
Old Mar 15, 2004 | 11:49 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
I posted this origanal message on 4 boards. I found the kid who actually did it. He supposedly dyno'ed this and improved +9hp and +14 tq. He claimed .5 seconds on his site. I know this isn't worth the effort. A good ram air system would do the same effect.
Check my site and i'll show you how i dropped .2 tenths for $10
I dropped my blazer's 0-60 .4 seconds for $30...........
Old Mar 15, 2004 | 11:50 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
this is the address sorry
Old Mar 16, 2004 | 12:24 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
All the negativity and that I've been seeing in response to this post has got me motivated.
I would actually be willing to wager that, there are greater hp per dollar gains to be found by using a leafblower to pressurize your intake tract than the hp per dollar gains found by using either a K&N air filter or underdrive pulleys, or both.
The loser buys a leafblower and pays for the dyno session.
Old Mar 17, 2004 | 01:16 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Exactly why do you think "pressurizing your intake tract" would be benefical? If the biggest leaf blower they have flows under 300cfm, and your weakest small block requires 400+ cfm, then how can it be anything but a restriction off idle?
Old Mar 17, 2004 | 01:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
they flow way beter than a engine needs. Trust me d00d, its what we use to get rid of big spidewr webs, you need lotas of blowing power for that...
Shane
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
