Twin Turbo Kit
Old Apr 3, 2004 | 12:25 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Twin Turbo Kit
This is the twin turbo kit
Old Apr 3, 2004 | 12:26 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
more pics
Pics on a 3rd gen
Old Apr 3, 2004 | 02:07 AM
bad_turbo's Avatar
Do you have to get special brackets for the accessories to clear the turbos?
Old Apr 3, 2004 | 02:14 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Judging form the Pic's you coul duse a 87 bracket setup and be fine.
Old Apr 3, 2004 | 05:52 PM
camaro_1983_383's Avatar
where can i find one of them for my Big block 85 camaro???
Old Apr 4, 2004 | 01:31 PM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Brackets?
I've designed the twin turbo headers around a V belt system. The only mods needed to fit the V belt is removal of almost all the A/C components and brackets and the use of a smaller alternator belt. I am not sure what are the mods, if needed, for serpentne belt equiped cars other than removal of the A/C componenets. I recomend for the serpentine owners to go to the junkyard and get a V belt setup and avoid any possible problems, after all most people are looking for the serpentine setup, wont be difficult to find a guy and trade it. Since this is not a system designed for those people wanting to keep their entire engine stock, mods are needed in the power accesories, anyone out there that wants a race twin turbo system with A/C, smog pump, and all the hoses in their stock location, this kit is not the one.
Downpipes are 3" dia and there is enough space for up to 3 1/2". No changes to the brakes, no delete of booster, power brakes or anything, just a few bends to the brake lines is needed as if when installing regular headers.
Old Apr 4, 2004 | 03:39 PM
Fred91GTA's Avatar
Car: 1991 GTA
You do real good work BBSDesigns. I'm sure we'll be doing some business in the future. Just some questions, will you be offering the piping from the Turbos to the intake? Will an intercooler be offerred? If not, what kind of intercooler setup would you recommend?
Old Apr 5, 2004 | 01:55 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Twin turbo piping
Thank you
This kit is for those looking for a custom work in their cars. I could offer the intake pipes thats now problem, but I would recomend the use of an intercooler to ease up the heat of the twin hair dryers. I am getting a custom intercooler for my 89' GTA with twin entry and a single outlet. I will be placing it where the A/C condensor use to be. Turbos are going to feed the intercooler thru pipes that run in both sides of the IC in the upper tank and flow will go down to the lower tank and to the right(driver's) side of the car and connect to the exsiting pipe that I borrowed from the single turbo kit I use to have. I hope that the picture is self explaining.
Old Apr 5, 2004 | 05:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Are you thinking of becoming a board sponsor?
Old Mar 21, 2006 | 11:31 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
bump can ya re-post the pics????
86Firebird86
Dec 26, 2015 07:21 AM
New2Chevy
Sep 28, 2015 12:35 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
