most out of a 305
Old Jun 26, 2004 | 01:27 AM
Yield's Avatar
Car: 91 Camaro Z28
Engine: 5.0 305 TPI
Transmission: Automatic
most out of a 305
what kinda of ratings has anybody gotten out of a 305 with a supercharger or a turbo...just curious. Although i doubt anyone has tried it because it would make more since to just swap it with a more powerful engine...but if anyone has i would love to know how it turned out
Old Jun 26, 2004 | 08:44 AM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
i had no supercharger or turbo on my 305 but used a 150 shot of nitrous and ran 11.40's all day long.
Old Jun 26, 2004 | 09:22 AM
misterjuice's Avatar
Car: 88 IROC
the most impressive # so far, that i've seen, is willie.... well over 400 rwhp if i'm not mistaken.......
I got 391 hp and 422 ft lb at the rear wheels.
305 TPI, 5 speed, stock heads, stock cam, Edelbrock 52mm tb/runners/baseplate/headers. SLP loudmouth catback. P600 Procharger 13 psi stock T5, stock rear end (3.45 9 bolt), 24 lb/hr SVO injectors.....stock programming.
Old Jun 27, 2004 | 11:12 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Did you have any trouble getting your 28" slicks under your car? I have a set of 28x10.5x15 MT's for my car but still waiting on the wheels. Looks like they will be a close fit....
Old Jun 28, 2004 | 01:09 AM
NEEDforSPEED's Avatar
Old Jun 28, 2004 | 07:17 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I guess I'll be the one to post Prestons 305 car
http://www.cecoatings.com/images/oth...oCars/preston/
he ran 9.80's with his old vortech. No clue what times with the Turbo
Old Jun 28, 2004 | 09:55 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
but isn't preston's motor a 4.020" bore motor? impressive non the less.
oh, and i am running a traditional 305, running mid/upper 13's on pump gas with no power adders. check sig for specs.
Old Jun 29, 2004 | 07:43 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
YES it is. but Its still a 305
BLOCK Bowtie 4.025” bore x 3.0” stroke-305 cu/in.
RODS Crower 6”
PISTONS J.E. 8.25 C.R.
CAM Crower hyd. roller 114° L.S.- .520” lift.
HEADS Trickflow G2 - 2.02” int. (275 CFM) – 1.6” exh. (210 cfm)
Old Jun 29, 2004 | 10:57 AM
mw66nova's Avatar
Engine: 7.0L
anyone got a dyno chart on that motor? what type of low end power does it make, what kind of rpm's does he spin...isn't this car cruised on the roads a certain amount each year with superb gas mileage too?
Old Jun 29, 2004 | 02:41 PM
BADDEST305's Avatar
Car: 1991 z-28
i had no problems fitting a 28" mickey thompson under there. but i now run phoenix (which is a way better tire the mt"s imo) they needed a little hammering on the innner wheel well.
Old Jun 29, 2004 | 05:05 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
No charts but here is a bunch of info for ya
http://www.cecoatings.com/images/oth...on/CONCEPT.htm
http://www.cecoatings.com/images/oth...CELERATION.htm
Old Jun 29, 2004 | 10:23 PM
83 Crossfire TA's Avatar
What model, size backspacing/offset wheel are you running? What sizes were/are the slicks? Ride height?
FWIW, I’ve been running 275 60 15 BFG DR’s on the street for about a month now on a car that’s lowered about as much as you would with some eibach pro springs. They actually measure a little over 28” and are 11.2” wide on a set of stock, firebird wheels (they’re supposed to be 15x7 with a ½” offset, they measure closer to 15x7.5 with a 5/8” offset), and they fit just about perfect, they just tuck into the wheel wells and don’t hit anywhere even during some fairly hard driving. The one time that I did find that they rub is coming out of my driveway (steep, big dip and have to make a turn in reverse), the driver’s side rubs the inner fender a little on the inside, but not enough to really make me do something about it). I _think_ that spacing them out about ¼” would prevent that and still clear the outer lip OK, but I haven’t tried it. I don’t think it would work as well with a wider rim since that would increase section width, at least not without some sheetmetal work
Old Jul 7, 2004 | 02:29 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
How long did this setup last? Did it take much abuse? That's my drivetrain, I have a 305 TPI, G92 5speed. Thanks...
Old Jul 7, 2004 | 06:21 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
For good small CID engines, look at TransAm. They're limited to 310 CID (not a 305, but close!) and 8200 rpm, and put out about 725 NA this year. I had the dyno chart of a 2001 vintage 14 degree engine, and it was pretty linear torque & hp from 4500-8200, with it just dropping off a little there...
Old Jul 7, 2004 | 10:24 PM
mw66nova's Avatar
Engine: 7.0L
again, another small stroke/big bore motor, i don't think putting that info out will help this guy.
her is my setup:
1985 chevy 305 block bored .030" over
stock cast crank
OHIO Crankshaft forged rods
l69 hyper replacements (9.5:1 comp ratio)
crane blue racer cam .442"/.465" 214*/224*
crane energizer aluminum roller rockers
edlebrock torker II (would run quicker with a good dual plane like a holley street dominator or edlebrock performer rpm)
holley dual feed 600cfm V.S.
standard HEI ignition with accel super coil
700r4 tranny
headman longtube headers with true dual moroso spiral muffs
3.73:1 disc rear
currently the car runs high 13's which is totally respectable coming out of a regularly driven car that is very streetable. i am switching to hooker 2460's and flowmaster force II catback and may see a small decrease in power, but with a better intake, i hope to gain it back. the 305's are solid motors if built right. however, i am planning a hossed-out 355 in the not-so-far future.
hope i helped
oh, and if you want to go faster, just add boost!
Old Jul 7, 2004 | 11:00 PM
Car: 88 IROC
I'm still driving the car around.........the supercharger has been on the car since 1997 or 1998 if i'm recalling correctly........back then the car had about 90,000 miles or so. now it has over 150,000.......still original motor/trans I did break the pinion gear on the 9 bolt in 2002...........replaced with the same unit.......
I drive the car pretty conservatively on the street, and I don't race......but the car is a dream to drive.
Old Jul 8, 2004 | 12:49 AM
Andris, I’d love to see that dyno graph (and any more details if you have them).
As far as the rest of this discussion, I’ve run a 13.8 at right around 96mph in my ’83 crossfire 305, and a 13.43@101 in a friend’s GF’s ’87 formula 305/5speed car. Both had stock long blocks, headers, exhaust and some other tweaking, but nothing special, just high mile stock 305’s with bolt ons, really. I fail to see what the problem is with making a 305 run, the problem is that you have to build it to take advantage of it’s geometry, instead of building it like you wish you had a 350. Breathing is a little more challenging on a 305 (not that much so, last summer I got some vortec heads to flow 234/213 at .500” on a 3.75” bore, pretty close to a 3.736” stock 305 bore, and smaller then a .030” over 305, that’s plenty to support close to 500hp NA), but detonation control is much easier.
Old Jul 8, 2004 | 11:39 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
what do you expect to run with 500na HP with a 305?
Old Jul 8, 2004 | 05:14 PM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks, sounds like a tempting set up...and I see your in NJ too.
Old Jul 8, 2004 | 11:22 PM
I’m not sure what you’re asking…
I had the heads flowed on the small bore because I wanted to see how well they would work on a 305 (for future reference). They were for a friend’s 350 that went in a full size dually (also the reason that they were so exhaust biased, he intended to supercharge the engine, but sold it before that happened), which dyno’ed in the low/mid 400hp range at the wheels (not bad considering the massive drivetrain and tires to soak up power).
As far as using them on a 305, they are a bit excessive… to _really_ get the most out of them you’d have to build a 305 built up for a hp peak at around 7500rpm. At some point I do intend to do a milder set + 305 + small turbo to replace the 350 in my full size truck, but that will wait till I kill the 350, which as of now is going strong.
Old Jul 21, 2004 | 05:49 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
how much can you stroke a 305 too? i know there is a 335 and a 340 stroker kit is that it?
Old Jul 21, 2004 | 11:03 PM
A 334 is a .030” over 305 with a 3.75” stroke (like a 400 or a 383), a 343 would be the same bore with a 3.85” stroke (like a 396 stroker).
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
