water injection guys inside
Old Jul 9, 2004 | 07:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am thinking of using a water injection setup. are they really that good?
Old Jul 10, 2004 | 11:28 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i have the smc kit i paid 500 dollars i think it is the best one out there,also a friend has one on his buick grand national can run 26 pound of boost with 89 octane.comes with 100psi pump in tank.
Old Jul 11, 2004 | 11:30 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i made my own you can see it on my site at
http://darcom.org
Old Jul 11, 2004 | 12:11 PM
Engine: ls1, LB9
looks great! I guess these things seem to work awsome for everyone I have talked to. I think this is just what I need to use.
Old Jul 11, 2004 | 09:15 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Same here. Home brew. Works fine..
-- Joe
Old Jul 11, 2004 | 11:30 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I had an SMC kit. I ran 23-24psi on 93 octane. It was an older single nozzle kit that had adjustable turn on and spray.
The new progressive kits are much better. Either the SMC or alkycontrol.com
Old Jul 12, 2004 | 09:29 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
linl to the SMC one?
Ive seen the alky one and its nice. never heard of the SMC unless Im just not catching on to the abreviation
Old Jul 12, 2004 | 10:41 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
SMCenterprises.com????? trying to remember......
Old Jul 12, 2004 | 12:43 PM
TTA 1387's Avatar
Yep, http://www.smcenterprises.com/
Mine was 3 years old, so a lot of new stuff was added. I never had a problem with mine but I was going to do the switch over to alkycontrol.com because of the progressive. Then Steve started a progressive one also. Either one will work better than the one I had.
Part throttle would chuggle with the setup I had. Once it started spraying, it sprayed at what ever the pump speed was. With the progressive, its a gradual build up of pressure to what ever you set for max pressure. So you can have it come on at real low boost and it will ramp up with more boost. You control how much the ramp up is.
Old Jul 12, 2004 | 06:20 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thanks.. I found it this morning right after I posted. Had a link saved for it.
Old Jul 15, 2004 | 12:41 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
http://darcom.org
Are you spraying the water/alky though the NOS plate behind the TB? I'm interested in running water injection in my TT IROC until I can put in larger injectors and custom tune the prom.
Old Jul 15, 2004 | 06:54 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
no i have a jet pluged in to the bottom of my intake tube after the blower. i use the plate for a 100 shot of nos.
Old Jul 16, 2004 | 10:20 AM
89JYturbo's Avatar
What did you use for the jet? Nitrous nozzle?
What controls do you use?
Old Jul 16, 2004 | 11:44 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
no it did not make the water mist like i had hoped ,so i found a nossel they sell ay the hardware store ,i cant rember the name of it but its in the section were they have the yard watering parts.its just a jet with holes. sorry its kinda of a veg ancer but i post a pic win i take it out to clean.
Old Jul 17, 2004 | 07:53 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here are a few good links for you for a DIY setup.
http://www.mcmaster.com/asp/DisplCtl...MMainWidth=812
http://www.turbomustangs.com/forums/...alky+injection
http://members.***.net/stevemonroe/AlcoholInjMod.html
http://forcedinduction.net/tech.html
http://www.dawesdevices.com/water.html
or just order up one of these
http://alkycontrol.com/
Old Jul 17, 2004 | 04:48 PM
89JYturbo's Avatar
Thanks for the info and links.
Old Jul 20, 2004 | 12:34 PM
rooster433's Avatar
I just built a awesome controller with a PWM controller..
BTW.. digikey sells map sensors for about 18 bucks..
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
