looking to run nitrous but no schrader valve?!?!
Old Aug 23, 2004 | 07:52 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Where would the schrader valve be on an 89 TBI camaro? I was looking and couldnt find one. Or where could i hook up to fuel? Also is there any way to incorperate an aftermarket schrader valve into the hard fuel line?
Old Aug 23, 2004 | 01:01 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
No shrader valve on them unfortunately . I'm cutting the rubber fuel line and putting a T in it to run to the nitrous solenoid. The TBI system runs at a low pressure, so hose clamps should do the trick (or so I hear, we should find out soon enough!).
Tony
Old Aug 23, 2004 | 05:27 PM
89305RS's Avatar
where would i get a tee for the fuel line and a -4an for the line to the solenoid? Also what size is the rubber fuel line?
Old Aug 25, 2004 | 11:06 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
I got most of the components for the T-line from Home Depot. They have brass pipe fittings, get a female T junction, then get two hose barbs (I think it's 1/8") for the sides. The top of the T needs an adapter from pipe thread to AN fittings. I got this at my local speed shop for like $3.00. As far as sealing it off, I'm pretty sure you don't need any sort of sealant on the threads, but don't quote me on this, like I said before, the TBI system runs at a fairly low pressure (<20 psi)
Tony
Old Aug 25, 2004 | 01:13 PM
89305RS's Avatar
well i just bit the bullet last night and purchased the $559 TBI n.o.s. kit. It will be here tomorrow. Ill see if i cant get some pics or at the least some info on this. Do you have any pics of your kit?
Old Aug 25, 2004 | 08:12 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
I'll get some up fairly soon, just gotta dig some sheez out of the garage.
Old Aug 26, 2004 | 07:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you're going to love when you get to the part of the install and it tells you to cut one of the lines to install a Tee..... :lala:
Old Aug 26, 2004 | 08:07 AM
89305RS's Avatar
well i figured that much. I just didnt want to go parts hunting and make like 4-5 trips for things that i come across alter. I would just as much want to have the COMPLETE kit sitting there and with all of the parts.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
gta90
Sep 15, 2015 04:00 PM
R3500
Aug 17, 2015 12:16 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
