Which engine for twin turbo
Subscribe
Aug 26, 2004 | 01:05 AM
I'm planning on getting an 82-87 305 carbureted camaro.
My plan is to eventually twin turbocharge the car. My question is what engine would be best to do this with?
Reply 0
Aug 26, 2004 | 09:16 AM
If turboing is your plan, don't get a carbed car. Get the TPI car and run the $58 code when its time for the turbos. That way you've already got the engine management under control and don't need to worry about not trusting a carb or swapping to fuel injection later.
Reply 0
Aug 26, 2004 | 09:42 AM
Quote:
bittermuch?
anyhoo like he said, if you plan to use the factory ECM, youd want a SD TPI motor... since it can run the $58 code with minimal hassle...
if you plan to use a aftermarket ECM, any SBC would work.
id reccomend a 350 though, just for the larger power output....
Reply 0
Aug 26, 2004 | 11:33 AM
heh. yes i'm quite annoyed lol
Spent an hour, TPI intake is off and all the harness is out. Carb intake should go back on in an hour, install fuel pressure regulator etc...i should be up and running in time to drive to work as a test drive.
Reply 0
Aug 26, 2004 | 07:25 PM
Thanks guys. I was wondering if there is a faq or some good articles that covers turboing the 350.
Or even a a site that covers a turbo project.
Reply 0
Aug 26, 2004 | 10:17 PM
Towards the bottom of the post I linked below are two book sources for turbo info. They will help tremendously if you are wanting to learn turbocharging.
https://www.thirdgen.org/techbb2/sho...hreadid=118353
Edit- Actually, I just gazed over that thread again- the books are actually listed in the first paragraph as well. There is other good info in that thread as well- I suggest using it!
Reply 0
Subscribe
