Some pics of my supercharged LT1.
Old Sep 28, 2004 | 04:57 PM
slimdawson's Avatar
Car: 1991 RS
Engine: Procharged LT1
http://pg.photos.yahoo.com/ph/evolve...edrs/my_photos
I will be taking some more as I have changed a couple things.
Old Sep 28, 2004 | 08:14 PM
92GTA's Avatar
Very nice.
Dude I must say I'm lovin the intake your're using for the blower. Custom or what? I want one for my install because I know the heat from my headers will kill my power...
Old Sep 28, 2004 | 11:22 PM
slimdawson's Avatar
Car: 1991 RS
Originally posted by 92GTA
Very nice.
Thanks. I made the intake out of 3 separate 4" mandrel bends. The radii were really wide so I had to tighten them up by cutting sections out and rewelding. That is about as good as it could have gotten. Any wider and it would have hit the brake proportioning valve and wouldn't have fit under the hood. I just moved the filter to outside the car. If it is nice tomorrow I will post a new pic up.
Old Sep 29, 2004 | 11:30 AM
slimdawson's Avatar
Car: 1991 RS
Some more are up now. Including the revised intake and filter location.
Old Sep 29, 2004 | 11:38 AM
92GTA's Avatar
Awesome, thank you for posting those:hail:
Old Sep 29, 2004 | 05:50 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Thats very nice. Did you make the blower bracket yourself? If not how much did it cost? Nice clean install. Btw How much power are you making?
Thanks,
Kory
Old Sep 29, 2004 | 09:25 PM
slimdawson's Avatar
Car: 1991 RS
Thanks. Yes, I designed and cut out the bracket myself. The only thing I didn't do was mill the section for balancer. I had a friend do that for me. I don't know much about machine shop
I don't know how much power I am making after the blower. I know it was a little over 300 at the wheels n/a. Put 8lbs of boost on that and who knows. I am waiting on my injectors to arrive and then shortly thereafter I will be getting it tuned.
Old Sep 30, 2004 | 02:23 AM
MdFormula350's Avatar
awesome setup and install!
Old Sep 30, 2004 | 07:19 AM
Guido's Avatar
Car: 2000 Trans Am
Noice! I dont believe Ive ever seen a supercharged LT1 in a 3rd gen. a few people have asked here but no one has ever done it. You can get the 4th gen kits to fit the 3rd gens to the best of my knowledge.
Again, nice job!
Old Sep 30, 2004 | 11:24 AM
slimdawson's Avatar
Car: 1991 RS
Again, nice job!
Thanks everyone. From what I saw with the p600b, you can't make it work(using only the 4th gen kit). I started with a 4th gen kit. The bracket placed the charger in the space occupied by the steering gear. I moved the gear to the framerail about a 1/4" and still couldn't get the bracket on. It needed at least another inch. That wasn't happening.
Maybe some of the other kits would fit but I don't know. I know that where the blower is currently, is very tight. Might not look like it but it is. !" higher and I am looking at hood clearance issues along with an even tighter turn in the intake. 1" lower, and I will be close to hitting headers and the steering gear. !" to the left and I will be hitting block. !" right and I will be close to the inner fender. You get the idea. I am just glad it all worked out.
Old Oct 1, 2004 | 07:23 PM
nick418's Avatar
Engine: L98, Hemi 6.2
now thats sweet:hail:
Old Oct 8, 2004 | 10:41 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
That a boy! Nice job!
Old Oct 14, 2004 | 07:49 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what are you usieng for tuning? stock pcm tuned for boost? boost referenced adj fpr? etc?
Old Oct 17, 2004 | 06:22 PM
slimdawson's Avatar
Car: 1991 RS
Right now, I am using stock tuning with an fmu. I recently got my 42lb injectors in so I will be installing them and driving to the dyno to have it professionally tuned.
Old Oct 18, 2004 | 02:05 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I'm loving the lack of a grille and the front mount intercooler. awesome job, and great looking car
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
-=Z28=-
Sep 24, 2015 10:21 AM
gt4373
Sep 9, 2015 10:29 AM
