How much CR with 6-8lbs. boost?
Old Sep 30, 2004 | 06:13 PM
daddy33's Avatar
Car: '85 Camaro
Hey guys right now i have my 383 and 700r4 tranny out of my car and thinking about buying the holley 144 supercharger with 6-8lbs boost. Right now my 383 has 10.5:1 CR. What will it boost it up to? I hope its not to much..... anyways any input will be great
Old Sep 30, 2004 | 06:19 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Read this info.....http://www.holley.com/HiOctn/TechSer...fo/SCTech.html
Old Oct 1, 2004 | 08:18 AM
nightrider87's Avatar
yeah ,intercooled or not plays a big role as well.
Old Oct 14, 2004 | 11:03 AM
stuckatcuse's Avatar
Car: Maybach
Engine: KA24DE-T
Transmission: M5
I have a question. If this is true, then how are people able to run mulitple (8+) lbs of boost on higher compression engines with pump gas? Those numbers must not be intercooled boost.
Old Oct 14, 2004 | 11:33 AM
right.
that link is about roots blowers, which aren't intercooled...save for a couple really special designs.
Old Oct 14, 2004 | 12:06 PM
Steven89Iroc's Avatar
There are many factors to consider, not just intercooling though it probably plays the biggest part. It depends also on how efficient that intercooling is, how much the air is heated before the intercooler, and how detonation resistant the combustion chambers are. Aluminum heads play a factor as well.
At any rate, if you have a proper setup 6 psi won't be a problem, I personally would lower the compression and run more boost though.
Old Oct 14, 2004 | 12:32 PM
Car: Maybach
Engine: KA24DE-T
Transmission: M5
nightrider87,
you ever hear the song by the tragically hip about "chagrin falls"
Old Oct 14, 2004 | 01:15 PM
i guess not. do you know the title?
Old Oct 14, 2004 | 03:45 PM
Car: Maybach
Engine: KA24DE-T
Transmission: M5
It's called Chagrin Falls. Sorry to drift off topic. Just curious.
Old Oct 14, 2004 | 03:56 PM
flrtin1's Avatar
Engine: S/B
Yes that site shows non intercooled #'s
I was running 15lbs on a 144 (although much less displacement than daddy33) on 100 octane no intercooler but I had 7.5:1 static compression. With that said I also was on the edge and replaced several pistons over the years that I had that setup.
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
