dist. advance, that retards under boost
Old Oct 6, 2004 | 07:26 AM
contactpatch's Avatar
Engine: sbc 350
I need suggestions for a method to reduce spark
advance, when under boost,
(the vacuum 'advance', needs to also retard)
with a non-computer distributor.
I know the are 'electronic' distributors that do this,
but they seem overpriced for what they are.
Old Oct 6, 2004 | 10:35 AM
Damon's Avatar
Long time ago somebody made a vacuum advance canister that would also retard under boost (sorta like "negative vacuum advance) instead of just going back to zero and sitting there. As I recall it was made for the old GM points style distributors, but maybe somebody still makes something like this for the HEI.
Alternatively, look into an aftermarket ignition amplifier box that has electronic/adjustable boost retard capabilities (MSD, etc.). If you're running boost you probably want to upgrade the ignition system anyway.
Old Oct 6, 2004 | 01:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I had one of those for an HEI distributor somewhere. Probably best to do it electronically though.
Old Oct 7, 2004 | 07:20 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Sometimes I see these on ebay for a reasonable price.
http://store.summitracing.com/defaul...&part=MSD-8762
Old Oct 8, 2004 | 11:53 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
look for msd btm box
Old Oct 9, 2004 | 03:10 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
wasn't that on the turbo corvairs (sp)
Old Oct 11, 2004 | 10:31 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Ditto, both MSD and Accel make auto retarding ignition boxes. Adustable by 1-5* per pound of boost at a maximum of 20*.
~Max
Old Oct 12, 2004 | 12:01 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I had one on a supercharged small block years ago, that was put on an HEI distributor - I believe it was made by B&M. Unfortunately, since they got rid of all their superchargers and related components, I'm sure it has long since been discontinued.
pjsparts
Oct 29, 2025 06:39 PM
customblackbird
Oct 1, 2015 04:30 PM
383backinblack
Sep 25, 2015 11:31 AM
Doobie52
Sep 11, 2015 06:19 PM
ericjon262
Sep 11, 2015 06:07 PM
